Safe way to get car on 4 jack stands?
Hi, figured I'd ask about this before I found out the hard way.....
What is the safe way to get a car completely off the ground on 4 jack stands? I've got a floor jack and can easily get the rear safely jacked up from the rear jack point and the 2 rear jack stands placed. I woulda thought all I'd have to do then is jack the front of the car up and place the other two jack stands in the front. But my jack stands came with an instructions flyer that warns not to jack the end of the vehicle if the car is already supported on the other end by two stands. I dunno if I believe that and I was going to go ahead and jack the front up, but I figured I'd ask first.... Thx! |
I dont see why it would be unsafe to put the car on all 4 jack stands. If the jack stands are rated for the weight of the car, then it should be fine. It's the same as how repair shops jack the cars with their lifts. They place it under the 4 locations and jack away!
You know the correct places to jack up the front and rear, correct? The tow hook and the little spot under the front. |
#3 (permalink) | |
I don't know, I think I'm going to try it anyways.... I'll jack the rear, place the rear stands, then swing the jack around to the front jack point, jack the front, and place the front stands. That stupid flyer has me paranoid now that when I jack the front while the rear is supported that I'm something's gonna go wrong.... we'll see! |
mmm...what a tasty burger
Jack the front from the middle where the arrow points to the jack point. Place jackstands on the side rails right behind the front tires. Jack the rear from the middle point right behind the sway bar and place jack stand on rails right in front of the rear tires.
See, no probs... ![]() Weput the front stands on a different place than what the pictures say on the stock jack that comes with the car. ![]()
#11 (permalink) |
ehh, id be worried about the car slipping down. side to side the frame gets wedged in the sides of the jack stand. of course, the weight of the car is going to cause a considerable amount of friction, but dependent on the height and the surfaces may be a bit smooth.
#12 (permalink) |
I'm going to be painting my calipers. The caliper paint instructions says to take all 4 wheels off at once, since you aren't supposed to reinstall the wheel for at least two hours after painting. The paint only stays paintable for a limited time too.
#14 (permalink) |
Teach me how to take pics
![]() P2R TBS/TBGs / Fujita SRI / Skunk2 10th Anv. Knob/Radiator Cap / TWM SS/ Auger Boot TWM Cable/Base Bushings / StrutKing DP Cover / JDM Dipstick / Cleared Head/Tails / My Car Build Thread - Amilia |
#15 (permalink) |
Before leaving the car on jack stands, remember to set your all jack stand at the same height.
Go front to back. Don't forget to loosen all lug nuts/wheel locks first. When lowering, lower in reverse order. Torque wheels to proper specs( 80 I believe). I think the hydraulic jack manufactures has to put that disclaimer in there for individuals that do not understand that if a portion of the car is already in the air, you are not suppose to raise the other half of the car beyond the point of the initial half, or the car can slide off the jack stands. To each their own. |
#19 (permalink) |
the tow hook is fine to jack it up on unless u barely have it on there! jack the front up on the bottom of the rad suppor(look under front of car behind splash shield for beam) put the stand on the jackpoints on the sides of the car.....then jack the rear up by either the tow hook or crossmember put the stands under the rear jack points on each side of the car and ur good to go :)
| pic request: your car on jack stands | dnbsi | Garage | 41 | 03-16-2008 11:31 PM |
| Custom double auxilary jack w/ Honda Aux Jack | locoJack | I.C.E., Electrical, Security, & Navigation | 10 | 09-04-2007 01:45 PM |
| SI stands for Shat myself Instantly... | countyboy4 | Driving Experience | 6 | 04-11-2007 08:52 AM |
| Where do you place the floor jack/stands when doing springs? | 06k20si | Suspension and Brakes | 9 | 01-16-2007 02:03 PM |
| '06 Si - Jack Stands? | televascular | Mechanical Problems & Technical Chat | 14 | 11-28-2006 06:24 PM |
