DIY: Painted R18 Engine Cover
This is my first DIY, so cut me some slack
![]() To paint your cover you're going to need a few things, most notably PATIENCE which I really don't have ![]()
Removal/Prep I started out by removing the cover which was really easy, just turn the little screws a quarter turn and it pops right off. * I wish all the tabs in the engine bay worked like this =\ ![]() Now that you have the cover off, you're gonna want to sand it and clean that sucker up real good. Engine contaminants and dust can lead to bad contact with the paint, and make your cover look spotty in some places. So please CLEAN IT before proceeding. Now what I did, and what you may decide to do may differ. I opted not to sand my cover after cleaning it thoroughly, and looking back on it, I probably should have. The Krylon Fusion paint states that its not necessary, but I'm going to sand mine back down to plastic and redo it. Sorry no pics of sanding =\, you just want to roughen up the plastic a little bit, no big grooves, just enough for the paint to bond well with. There may be better ways to block off the lettering, but at the time I hadn't fully thought it through and just used blue painters tape. I'm going to experiment with melted wax possibly on my friends cover, I think it should work. Depending on those results, I'll add that procedure to this later on. The Tape Method You want to lay the tape over the HONDA lettering, and applying pressure over the letters. This allowed the HONDA to be seen relatively easily. You then want to either trace out the letters on the back of the tape then cut it out, or cut it with an exact-o knife or razor blade right on the plastic. I again, was in a rush and chose option 2, I recommend option 1 though Should come out looking like this ![]() Here is the R18 I used, if anyone's interested ![]() To make a decal with the painters tape with the printed text, make sure you trace the lettering on the non-sticky side of the tape upside down. so it should look like this on the back of the tape ![]() Wax method This is a work in progress, though you may decide to try it. I plan on melting wax over the HONDA lettering and then carefully carving away the excess so that it leaves me with said lettering embossed with wax. That way, hopefully, spray paint won't adhere to where its not meant to. Heres a sketch ![]() If anyone has a better way, feel free to share it with us. -------------------------------------------------------------- Painting To attain the different colors, you're not going to want to put the painters tape letters you cut out onto the cover yet, instead go ahead and paint the whole thing white. It will bring out the other color very well compared to just being painted on black plastic. You want to take this very slowly, spraying evenly across the engine cover. Take your time and do a few thin coats, waiting about 30 seconds to a minute between coats. ![]() Granted I didn't do that, here is a picture of what it should roughly look like. This was after I put 3 heavy coats on, because I was in a hurry and didn't prep my plastic very well. I wasn't satisfied with the finish until the third coat. I don't recommend heavy coats needless to say. When you're satisfied with the color, let it all dry for about 10-15 minutes or so to allow the paint to bond with the plastic. Once its all done drying, go ahead and put the HONDA tape letters you cut out over the newly painted white HONDA. Again this is just what I did, I really don't know if its the best approach, but it worked for me. You can also at this time put the R18 letters you cut out on, if you desire. Make sure all of the tape is pressed down firm and secure, as you don't want your second color to intrude on your first one. unpainted example- ![]() When you feel like there is no way the paint could get under the tape, go ahead and start painting with your second color. Again use multiple thin coats for the best result. After you're done coating it, allow it about 10-15 minutes to dry. Now the hard part... well somewhat hard You may have noticed that the paint, red in my case, has covered the blue painters tape completely, leaving you no where to remove the tape. This is where a razor blade or exact-o knife comes in handy. To get the tape off, you want to very carefully, and I mean VERY carefully slice the paint around the edges of where the tape is. This will allow for a clean removal of the tape. You may want to go over where you've cut a few times with the blade, just to make sure you can cleanly remove it. After all of that is said and done you should have something that resembles this. ![]() After you've removed the tape lettering, its time to apply the clear coat. Not only with this make the paint appear glossy, it will also provide some protection. The picture above is after the clear coat has been applied. Allow the clear coat about half an hour or so to dry. Once its dry, go ahead and install it back onto your engine and enjoy! If you have any questions please ask, and do realize that results may vary from person to person. |
Great job! The red might be a little too bright, but still a job well done.
BTW! Instead of using masking take etc. you can use petroleum jelly ![]() then wipe off when paint dries. Just watch where it goes and only put it on what you want. It's an old painting trick |
#10 (permalink) | ||||
r18 sticker white coats drying honda sticker red coats drying removal of stickers clearcoat Quote:
| DIY: JDM engine cover | Sion0x | Engine | 70 | 07-24-2008 08:31 PM |
| R18 Engine cover | PokeyD16Z | Inside and Out | 214 | 07-03-2008 05:28 PM |
| Painted R18 Cover | gg_civ615 | Do It Yourself Articles | 9 | 03-26-2008 04:35 PM |
| Engine Cover and Caps Painted *Pics* | 06-Civic-EX | Introduction & Pictures | 26 | 02-17-2007 09:59 PM |
| R18 Engine cover | chenyuelin | Inside and Out | 5 | 12-17-2006 05:15 PM |
