Old 06-04-2006, 02:43 PM   #1 (permalink)
Extra Dim/Extra Bright Speedo
So I noticed not too long ago that my Speedometer was not as bright as it used to be. After a little playing, I figured out why....
  • press the ">" button until your speedo is at its brightest setting... Make a mental note of how bright it is.
  • Turn off your car engine
  • turn the key to ACC
  • Press the "<" button to reduce lighting on your speedometer and radio until it is at its lowest
  • Turn on the car again....
  • Press the "<" button again until it is at its lowest (if not there already)
  • Now Press the ">" button until it is at its brightest setting
    Compare the highest brightness now against what it was in the first step. It is not as bright.... TO fix this, repeat steps only at the 4th step, press the ">" button instead of the "<" button until it is at its brightest....
    Let me know if I'm tripping out or what, but I experienced this and repeated it a second time to make sure it was actually happening.... Whether you think this is a bug or a feature or what... I called it first... :)
incongruent is offline   Reply With Quote
Old 06-04-2006, 06:02 PM   #2 (permalink)
jspecFG's Avatar
I don't know, mine seems pretty bright.. hurts my eyes sometimes lol
jspecFG is offline   Reply With Quote
Old 06-04-2006, 06:34 PM   #3 (permalink)
Mini Me!
Cybergypsy's Avatar
I know when the lights are on it dims....
Old 06-05-2006, 07:48 AM   #4 (permalink)
I believe there are 2 settings...
One for headlights off and one for headlights on.
I have adjusted mine so that the speedo dims when I turn on my headlights. This reduces the glare at night.
jnuzzi is offline   Reply With Quote
Old 06-05-2006, 08:59 AM   #5 (permalink)
I like it bright... it keeps me awake...
Old 06-05-2006, 09:47 AM   #6 (permalink)
VoLTr0n's Avatar
you're right there are two settings. when the headlights are off the speedo is at the brightest setting. when you turn your headlights on it goes to whatever you set it to.
VoLTr0n is offline   Reply With Quote
Old 06-05-2006, 10:29 AM   #7 (permalink)
arisenfury's Avatar
Nikon & dSLR squad #6
I'm not sure about other models, but in my DX, when I am adjusting the brightness, on the Tachometer, 6 or 7 little boxes go across the display. As you dim the brightness, boxes disappear, the lowest setting I think only has one. And the brightest has all of them. It's an easy way to tell what setting you're at.
arisenfury is offline   Reply With Quote
Old 06-05-2006, 12:46 PM   #8 (permalink)
I believe that I was able to set both of these, not just one.
I can check this again tonight after work.
Old 06-05-2006, 01:16 PM   #9 (permalink)
2RotorMotor's Avatar
RIght, but you can set both to your desire... You can have both at extra bright or extra dim. I have mine set at extra bright for both nightime and daytime..
2RotorMotor is offline   Reply With Quote
Old 06-05-2006, 01:20 PM   #10 (permalink)
SpeedDemon's Avatar
They call me, El Diablo.
Yea, and theres no need to turn the car, and off back again, cause it will stay Bright, or Dim depending on how you adjust it. I tend to scare people sometimes, I get next to them with the dim inside lights on, and then as soon as they look over, I start to increase the Lighting on the rpms/speedometer, and Bam! Bright as hell, and then I drive off. Its all about the Fun.
SpeedDemon is offline   Reply With Quote
Old 06-05-2006, 01:24 PM   #11 (permalink)
Mini Me!
Cybergypsy's Avatar
I thought thier were one less square when you turn your headlights on and there is no way to fix it????
Old 06-05-2006, 01:27 PM   #12 (permalink)
no there is.. You have the same adjustability with the lights on/off.. BTW its kinda messed up that you don't reply to the pm's...
Old 06-05-2006, 02:07 PM   #13 (permalink)
dentrecords's Avatar
whoa.. I bet that lights up the interior pretty well. I use one lower than the highest setting at night, as I find the full intensity is a bit distracting from the road.
Originally Posted by ryker
A sign how things will become under Obama. Liberals controlling every aspect of our life even on how we post on a chat board.
Old 06-05-2006, 02:34 PM   #14 (permalink)
miami is pretty well lit up, so glare is not really a problem...
Old 06-05-2006, 02:45 PM   #15 (permalink)
Mini Me!
Cybergypsy's Avatar
I get 6 squares with the lights off...
and max 5 squares with the head lights on......is there a sixTh...mine does ot do it...
Old 06-05-2006, 02:46 PM   #16 (permalink)
Mini Me!
Cybergypsy's Avatar
All you write is i am bored talk to me...lets do 20 ?????s...ok...
Old 06-05-2006, 03:10 PM   #17 (permalink)
you gotta keep it pressed... and yea, im down for 20 questions...
Old 06-05-2006, 03:53 PM   #18 (permalink)
[IVI]'s Avatar
Bryan
agreed - hold down the > button for a few seconds and it will change to the brightest mode, even with the headlights on
[IVI] is offline   Reply With Quote
Old 06-07-2006, 07:59 PM   #19 (permalink)
PokeyD16Z's Avatar
on a side note....you can set it to whatever you want for the night setting and then if you turn on your headlights during the day and hold the + to make it completely bright (all boxes...same as daytime setting...or whatever other brightness you want), you can get back to where you were (for the original night setting) with just one push of the - button. If you let it go on the way up (with the +) and do it one box at a time, you'll lose the memory setting.
Old 06-09-2006, 09:07 AM   #20 (permalink)
understood... but what i am saying is this....
if mode1 = [................]
and mode2 = [oooooooooo]
it is LESS BRIGHT than
mode 1= [ oooooooooooo]
and mode 2 = [oooooooooooo]
Am I being clear?
Can you change the color of the speedo light mglai1987 Lighting, H.I.D.'s, & Neon 1 04-15-2006 07:34 AM
