Modified Upper/Lower Airbox + Modified MAF - 8th Generation Honda Civic Forum
Old 03-05-2008, 07:26 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Nick
I plan on cutting the veins out of the upper part of the stock airbox and sanding it down to a smooth finish on the upper and lower part of the upper airbox. I also plan on doing X's modified MAF to allow more airflow. Personally I dont think there is a need for the CRV tube X used in his intake so Im going to just use the stock one. I will also be using P2R TBG/TBS/TBG. For the lower part of the intake (the part thats behind the foglight. I plan on cutting the front off of it so it will kind of be like a RAM but not really just alows air to flow into it easyer... I plan on doing this within the next week or two I will try to get a dyno before and after for you guys. By the way this will be on a stock Si. I also have a friend with a moded Si e/h/i I will also try to get him to dyno with his current intake and with mine for you guys aswell. I will try to update this as much as possible and once Im finshed I will def make this a DIY if the gains are sufficent enough. Let me guys know what you think about my idea... Im trying to get the most hp/tq while spending the least amount of $ (like the xintake $300) with mine you would have to spend around 80-90 for the P2R goodies thats about it. I dont want to use the K&N filter because its oiled so Im also just going to stick with the stock one. I also have a version 2 in my head but want to see how this one works out then we will see about the v2.
I hope it works out this can give you kinda the idea im going for
Supercharged is offline
Old 03-05-2008, 08:00 PM   #2 (permalink)
Nick
Im looking to get around the same gains as the X intake the whole thing Im looking to gain is a bit more tq and a perfect air to fuel ratio I have not dought it will make hp but the tq and afr is what Im hoping for. What I believe makes hp/tq/afr for the xintake is 70% the MAF 10% P2R Goodies and the other 20% is the apexi filter that Im not going to be using but with my setup you should have cooler air going in aswell so Im hoping that will help me out a little bit.
Supercharged is offline   Reply With Quote
Old 03-05-2008, 08:04 PM   #3 (permalink)
I'm in for results.... Hopefully it'll be a bonefied diy alternative to the x - which I luv, but it's loud as fawk at wot....
razasasin is offline   Reply With Quote
Old 03-05-2008, 08:05 PM   #4 (permalink)
don't forget a drop-in amsoil or other high flow filter...
Old 03-05-2008, 08:10 PM   #5 (permalink)
Zeuceone's Avatar
dont expect to much. the stock filter is very restrictive.
Old 03-05-2008, 08:19 PM   #6 (permalink)
Nick
Do we have any other filters other than the K&N? I would like to get an aftermart one that is less restrictive but not an oiled filter like the K&N.
Old 03-05-2008, 08:26 PM   #7 (permalink)
Zeuceone's Avatar
for stock replacement idk.
Old 03-05-2008, 08:37 PM   #8 (permalink)
Nick
I mean I do have another plan if the gains arnt what I want them to be with the v1 because I did think of the filter but I figured with the P2R goodies and the MAF I would get better than stock... I didnt really want to show anyone my v2 until I did my v1 but I guess I can show yall my idea for v2
Its kinda like a poor mans power chamber I guess you could say basically the same as v1 minus the the lower part is replaced with an apexi filter. and the removal of the stock filter.
Attachment 11183
Old 03-05-2008, 08:46 PM   #9 (permalink)
Nick
Bump for people to check out v1 and v2 let me know what you think... input is always welcome!!!
Old 03-05-2008, 08:51 PM   #10 (permalink)
i like V1 more... but i don't think u will see true gains from it on the dyno seeing as it's kinda hard to replicate the ram effect on the dyno...
u will see gains from just adding the P2R stuff that's a fact... have u done a baseline dyno??
Old 03-05-2008, 08:52 PM   #11 (permalink)
Nick
I havent done a base line dyno as of yet. Was hoping to get one this weekend then start on my v1. then dyno again. then start v2. and see the power difference...
Old 03-05-2008, 08:59 PM   #12 (permalink)
02civicsi's Avatar
Location: Seeing the beauty of the world in a drop of morning dew
I am the Juggernaut!!!
My vote is for V1, I just removed the resonator last weekend. I'm already runing a K&N drop-in filter in the unmodded stock intake box. I'm very tempted to attempt your V1 myself because unless I do try this the OEM resonator will never go back on my car.
02civicsi is offline   Reply With Quote
Old 03-05-2008, 09:04 PM   #13 (permalink)
Nick
Basically what I wanted to do was just chop the front of it off (nearest to the foglight/or foglight slot) and sand the inside out like the upper airbox... to make the air move more smoothly... But again I would highly suggest doing the MAF mod aswell because I believe thats going to be 70-80% of the hp/tq gain and keep the afr nice... also get the P2R goodies they work for a fact...
Old 03-05-2008, 09:08 PM   #14 (permalink)
AXIS's Avatar
Chance McDurgin
I like your idea of V1, its something i was actually thinkin of doin. Would the CRV airbox fit in our engine bay i've never seen one, just wondering if the box is bigger
AXIS is online now   Reply With Quote
Old 03-05-2008, 09:11 PM   #15 (permalink)
Nick
The CRV airbox is kinda like the RSX airbox so no it wont fit in our car... It would be nice to find a larger box but I dont feel like searching and searching so Im just going to go with the stock box. Sanding and sanding and some more sanding... lol will give you a little more room in the airbox...
Old 03-05-2008, 09:21 PM   #16 (permalink)
Raven07Si's Avatar
Daniel
Good Luck man, can't wait for the results!
Raven07Si is offline   Reply With Quote
Old 03-05-2008, 09:23 PM   #17 (permalink)
02civicsi's Avatar
What you want is the rubber tube that goes from the CRV intake box to the TB. The CRV tube is bigger so it has more volume.
Old 03-05-2008, 09:27 PM   #18 (permalink)
Nick
^ ture it does has more volume but i dont think thats whats making his power...
Old 03-05-2008, 09:31 PM   #19 (permalink)
02civicsi's Avatar
I do believe it's an integral part of his intake.
Old 03-06-2008, 12:58 PM   #20 (permalink)
again, don't forget a drop-in amsoil or other high flow filter...
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/82742-modified-upper-lower-airbox-modified-maf.html
8th Generation Honda Civic Forum This thread Refback 03-05-2008 08:21 PM
Modded MAF + Injen CAI el_ache_veintidos Intake & Spacer Discussion 52 10-14-2007 06:01 AM
modified stock airbox slow4drsi Bolt-Ons And All-Motor 43 09-29-2007 03:54 PM
