#1 (permalink)
Six eyes
Dome light leads???
Does anyone know how to access the positive lead for the dome lights?
I want to put in LED courtesy lights, but I want them to turn on when you open the door and fade out when you start the car, so I'm guessing there should be a lead under the dash somewhere? I tried looking, but I got pissed off and quit... fortunately I have 8thcivic to fall back on ![]() Thanks! J p.s. I'm going to go wash the bugs off my car while I wait
#2 (permalink) | |
Six eyes
Okay, I'm stupid and I don't know how to edit... :rolleyes:
The reason I mentioned the dome lights is because if I splice the dome light lead, I can have the LEDs behave exactly the way they do... if I can find that lead. J
The domelight wire should be a pink wire on the back of the fuse box in an 8 pin plug. Not 100% so make sure you check the wire before just connecting.
Also, you don't want to power it with 12 volt power. 12 volts can actually burn up an LED. If you have LEDs hooked in series it should be fine, because less voltage is going to the LEDs. You can also use a resistor inline if you are just powering one LED. Here are some good sites about LEDs, especially if you are making your own groups of LEDs and not just buying a pre-built light bar of them. The pre built ones from stores should be fine to hook up, they come with resistors and crap in them I believe. http://www.theledlight.com/ledcircuits.html http://metku.net/index.html?sect=vie...calc/index_eng |
#4 (permalink) | ||
Six eyes
![]() Thanks for the info though... me and my voltmeter have a date with the fusebox... yahoo ![]() J
I tried to hardwire my V1 without success today.
But I think I found the wire you're talking about! Because after the dome lights went out, so did my radar detector. I'm still looking for the 12v accessory/ignition wire.I have the dome light with map lights, sunroof, and navi. So, if you have this as well, it *should* be the same. If you take out the assembly, you should see two connectors, one 3-pin, and another massive one that houses many more wires. On the 3-pin one, there is a turquiose wire (not the dark blue one). That is the positive wire. The dark blue one should be the ground. (check first before you start splicing!!!) HTH! |
#7 (permalink) | ||
Six eyes
I would have played around with it more yesterday, but I was gearing up for a 250-mile trip later in the day, so I didn't want to have any problems with the car before heading out
#8 (permalink) | |
#9 (permalink) | ||
Six eyes
Is the turquoise wire you're referring to on the back of the fusebox or the front? I played around with the fusebox again yesterday, and I still can't get it out or find the lead that goes to the dome lights. I thought this was going to be an easy install, but it doesn't seem to be turning out that way... ![]() J
#10 (permalink) | |
I would like to do something similar to this. Have you found the lead to the dome light yet? |
#11 (permalink) | ||
Six eyes
If you find out how to access those harnesses, PLEASE let me know! ![]() J
#13 (permalink) | ||
Six eyes
Let me know what you find out! J
#14 (permalink) |
Will do, j. I'll probably mess around with it on saturday. I've got a date with my dad's volt meter.
I found this link for installing an auto day/night mirror that might help. http://www.hondapartsdeals.com/honda...ght_mirror.pdf there is a three pin connector shown on the page 2 (left side) of that install guide. Would that be the connector woohoo was talking about? |
#15 (permalink) | ||
Six eyes
![]() The idea of having to hammer on the A-pillar cover to get it off doesn't thrill me either, but if it has to be done... I can just envision the airbag going off in my face the moment I hit the cover
#18 (permalink) |
I found itUnder the fuse box there is a blue connector. On this connector there is a pink wire and a light blue wire next to it. The light blue is your positive wire. And the pink wire is a controled ground wire. With it being a controled ground wire, a test light would not always light up, so you might have tested it and moved on to other wires with out knowing you had the correct wire... Ah I think that search deserves a beer.
#19 (permalink) | |
![]() Join Date: Apr 2006
Dent
#20 (permalink) | ||
Six eyes
![]() Thanks for the find! I think you saved me a lot of work! J
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/8168-dome-light-leads.html
| DIY: Courtesy Lights to Dome Light w/PICS - Page 5 - 8th Generation Honda Civic Forum | This thread | Refback | 01-04-2008 10:15 AM | |
| How To and Pics for mod of courtesy light | fesersoft | Lighting | 23 | 05-17-2009 04:31 AM |
| Have to Remove Rear Bumper Cover to Replace Tail Light | civicboy | Mechanical Problems & Technical Chat | 15 | 01-01-2008 02:47 PM |
| Sliver Star light bulbs vs. Xenon light bulbs | Hybrid_Customs | Lighting, H.I.D.'s, & Neon | 14 | 05-19-2006 12:18 AM |
| a new light bulbs concern.... | leo3000 | I.C.E., Electrical, Security, & Navigation | 14 | 03-04-2006 07:29 PM |
| want to own luke's light saber? | webby | Water Cooler | 6 | 07-11-2005 09:07 PM |
