Info on changing Power Steering Fluid...
I was looking through the DIY forum and did not see any info on how to change or flush the power steering fluid. I have read elsewhere this is good to do every 1 or 2 years and will help keep the power steering system in tip top shape.
Does anyone have a DIY or any info on how to change or flush the power steering in the 8th gen Civics?? I know the Si has electronic PS but the rest of us have hydrolic so need to change it every now and then. I know we are supposed to use only Honda Power Steering fluid - so I am not asking what to use - just how to do it. Thanks in advance |
I looked it up the service manual and here's the basics. (However I'm sure power steering is something you don't need to worry about for a long time):
Use honda fluid. Total to replace should be 0.27 quarts. Pull out the reservoir. (it slides out) Pull out the upper hose attached to the reservoir (the return hose) Drain the reservoir. then attach another hose to the return hose so you can drain it into a container. Start the car, let it run, turn the steering wheel lock to lock a few times. Wait till all the fluid comes out and shut off engine. Fill up the reservoir. Start car, let it run, do same thing with steering wheel. (bleeds air out) Add fluid as needed. Last edited by TeaSX; 02-11-2008 at 01:19 AM. |
| Low Power Steering Fluid | victor | Mechanical Problems & Technical Chat | 15 | 02-04-2008 08:55 PM |
| changing Auto. Transmission Fluid | alexxtang | Bolt-Ons And All-Motor | 8 | 09-30-2007 09:08 PM |
| Changing Blinker Fluid | OhSixCivic | Garage | 43 | 07-18-2007 07:22 PM |
| Power Steering Fluid | victor | Mechanical Problems & Technical Chat | 17 | 12-18-2006 04:24 PM |
