Old 02-05-2008, 02:42 AM   #1 (permalink)
Incantation's Avatar
remote wire
hey guys.. was installing an amp/sub in my girl's civic and i can't find a remote wire.. can anyone tell me where i can splice in?
07 civic base model
thanks!
(i saw there is a link to a thread regarding this in the DIY section but for some reason i do not have permission to access the page..)
Incantation is offline
Old 02-05-2008, 11:49 AM   #2 (permalink)
Duce2k's Avatar
Try this one.
Amp Remote On How-To - Civic Sedan w/ Pics - 8th Generation Honda Civic Forum
Duce2k is offline
Old 02-05-2008, 01:52 PM   #3 (permalink)
maxxnitro88's Avatar
Greg
or you could find a fuse that comes on with the ignition, on my 95 accord i used the fuel pump fuse, and wrapped the wire around it so when i turned the key to 2 the amp would be powered up. the remote wire does not carry any current it only acts as a positive lead to trip a relay to then power the amp so that is why any fuse that powers stuff like that will work.
maxxnitro88 is offline
Old 02-05-2008, 02:08 PM   #4 (permalink)
8thcivic Sponsor
strutking's Avatar
tap into lights or speaker?
FREE Shipping within the US!
10% off coupon code: 8thcivic
strutking is offline
Old 02-05-2008, 02:27 PM   #5 (permalink)
cool.. i ran the line into the fusebox where the head-unit connects but that is temp fix.. i'll try to see which of your guys solutions works the best tonight.. thanks very much
Old 02-07-2008, 11:54 PM   #6 (permalink)
i tapped my remote wire to the antenna like the one link in the 2nd post.. it works great. haven't had a problem for over half a year.
itz smokin is offline
Old 02-08-2008, 12:04 AM   #7 (permalink)
FG-JOE's Avatar
Joseph
i used a remote from the stock amp under the shifter. but that was for the SI
FG-JOE is offline
Old 07-04-2008, 11:05 AM   #8 (permalink)
tcd2004's Avatar
Digging this back up, but what wire on the amp did you tap into?
tcd2004 is offline
Old 07-27-2008, 10:08 PM   #9 (permalink)
i went to the honda dealership and they printed out the wiring diagram for the stock amp in my si. If you can't read it i'm sure a tech can point you to the right wire np. Mine was a purple wire to the amp under the driver seat.
projectk20si is offline
Can you use Power and Remote off same wire? SleepingEclipse I.C.E., Electrical, Security, & Navigation 20 12-09-2007 06:52 PM
Remote Wire Hayaku Kenji I.C.E., Electrical, Security, & Navigation 2 09-11-2007 04:00 PM
Remote Amp Wire!?!?!?! FG207Si Mechanical Problems & Technical Chat 9 08-27-2007 09:42 AM
Remote wire slamminarm I.C.E., Electrical, Security, & Navigation 3 03-02-2007 12:48 AM
where to run a remote wire from? gray06 I.C.E., Electrical, Security, & Navigation 7 03-13-2006 11:50 AM
