Old 01-29-2008, 01:29 AM   #1 (permalink)
all motor K'S's Avatar
hookin up 4ch amp w/ stock hu?
i was planing to hooh a amp to my hi's with the stock hu and i don't want to cut the wires on the factory harness has any1 done this? i think that u can do it where the harness comes from the hu to where it go factory amp to a LOC then rca to amp then speaker wires from amp to a amp bypass to get the feed to speakers without rewiring the whole car. can someone tell me if they think it will work?
all motor K'S is offline
Old 01-29-2008, 01:52 AM   #2 (permalink)
this is a diagram that i think will help
Old 01-29-2008, 12:07 PM   #3 (permalink)
Duce2k's Avatar
I think there was a DIY somewhere on the site for that, you can do a search, I think the output from the premium stereo is low level so you won't need an LOC if you're bypassing the factory amp
Duce2k is offline
Old 01-31-2008, 03:15 PM   #4 (permalink)
Actually the factory HU outputs on the EX and Si aren't speaker level or line level (RCA) they're actually differential balanced low level outputs, so you cant use a regular LOC, you need a differential balanced LOC i believe theres one by peripherial vendetta. You could also get a 4ch amp that has differential balanced inputs, however there are few models that have that
Mulk is offline
Old 01-31-2008, 04:03 PM   #5 (permalink)
Sambos | We the BEST!
infinite0216's Avatar
Andy
i kno i had this installation place use all my stock headunit to connect my amp and single sub. i'll look at the wiring when i get a chance and let you know on what i think they did.
infinite0216 is offline
Old 01-31-2008, 08:37 PM   #6 (permalink)
that would be great. infinite did u have them put a amp on ur highs too? the problem that i have ie that my sub out power my highs big time and i hate that so much. I'm just tryin not to cut the wire harness
Old 01-31-2008, 08:38 PM   #7 (permalink)
Tam Ngo
if you stop at best buy, they have all the harnesses you need so that you won't have to splice up the wires.
trystar is offline
Old 01-31-2008, 10:59 PM   #8 (permalink)
Andy
you know the wire to comes into the stock sub? well basically what they did was, they cut that wire so disconnect the stock sub, then ran a wire from the wire they just cut to the amp. from the amp to the sub. then just powered everything thru the amp/battery. i'll try to get pictures tomorrow if i have time.
Old 02-02-2008, 10:28 PM   #9 (permalink)
teljoundi's Avatar
which stock head unit do you have? makes a diffrences in where the factory amp is located
teljoundi is offline
Old 02-02-2008, 11:40 PM   #10 (permalink)
i have the reg. one no nav
hi all, another stock si lol karpismar Introduction & Pictures 21 12-07-2006 11:17 PM
wiring subs into the stock wiring and stock radio? 2006fijibluesi I.C.E., Electrical, Security, & Navigation 6 04-18-2006 01:48 PM
