Old 05-12-2006, 05:14 PM   #1 (permalink)
Removing Tailights
Hello..Im attempting to remove the entire tailight assembly so I can tint my tailights. I'm having trouble removing it...i tried removing all of the screws or whatever from inside the trunk but it still didnt come out. Any help woudl be appreciated.
ballplaya4237 is offline
Old 05-16-2006, 10:32 PM   #2 (permalink)
kenchan's Avatar
I'd like to know the details, if anyone has them, on removing the rear
tail light assembly. Car got hit in the parking lot by our UPS truck (some newb
driver) and the tail light cracked along with some minor damage on the
rear bumper and quarter panel. body shop quoted me $970 to fix cause
the quarter panel needs to be filled and whole side of the car needs to
be blended to match color.... being a PDR tech myself, i thought the
estimate was complete bs.
Im doing the repair on my own and will charge UPS's insurance to reimburse
me for the parts, paint, and some labor.
I think the rear bumper needs to be removed to remove the tail light. i
removed the 4 nuts today on the backside of the tail light but it would not
come off...
Is it just the 2-3 phillips head screws by the fender opening, 2 clips on
the bottom and the 2 torex (or hex) screws by the trunk opening like
on the coupes?
thanks.
kenchan is offline
Old 05-17-2006, 12:19 AM   #3 (permalink)
yep
2 Screws
2 Clips
2 Hex
then just pull with a little force..pops right off
Old 05-17-2006, 08:32 AM   #4 (permalink)
kenchan's Avatar
^^ thanks. i forgot to mention I have a sedan..is that the same for the sedans?
Also, you said pull... which way? aft or down? thanks. :)
kenchan is offline
Old 05-17-2006, 09:32 PM   #5 (permalink)
Not sure about the sedan..but id imagine so..
and pull out...not down..
Old 05-18-2006, 12:48 AM   #6 (permalink)
kenchan's Avatar
^ thanks. I went to honda to order my tailight today...
should have the car fixed by this weekend if the weather behaves... :)
kenchan is offline
Old 05-19-2006, 01:17 AM   #7 (permalink)
kenchan's Avatar
Here's how to remove the rear bumper on the sedans.
Remove 4 Phillips screws per side on the fender liner (one is pointing upward),2 clips on the bottom, and 2 hex screws at the trunk opening. You need to gently pull out the sides of the bumpers (one side at a time) then gently pull the bumper aft. Then do the other side.
The tail light removal will require you to pull the bumper cover off to remove the bracket the lights are sitting on. There are 2 nuts on the brackets you need to remove.
My car is 95% fixed. I got my new taillight to replace the broken one. Just need to touchup and wet sand the light scuffing on the bumper
kenchan is offline
Old 05-19-2006, 08:41 AM   #8 (permalink)
kenchan's Avatar
OT... ^^ i did that post from my BlackBerry. looks pretty good, huh?
kenchan is offline
Old 05-21-2006, 11:48 AM   #9 (permalink)
Hail corporate masters.
J-Ro's Avatar
Jason
how do you actually remove the taillight on the coupe? I remove the four nuts, but there's still something holding it back... I have a feeling that it's something small that I'm missing that is going to make me feel like a retard :rolleyes:
I want to take them out to start researching how I'm going to install LED taillights :)
Thanks,
J
Epic Northeast Meet quotes:
Originally Posted by portabuddy
People sometimes think I'm pregnant, but I'm actually not.
Originally Posted by jrMartinez24
You don't look Canadian. You look like you're from Boston.
J-Ro is offline
Old 05-21-2006, 02:51 PM   #10 (permalink)
You have to remove the rear bumper. There's one screw in each tailight holding it back.
Old 05-21-2006, 07:32 PM   #11 (permalink)
kenchan's Avatar
yeh, the light sits on a bracket that holds the bumper in place.
On the sedans, you actually need to remove the bracket to get the
tailight off...i think it might be the same on the coupes as there are
posts under the lamp that secures itself into the bracket... unless
you're forcing the bracket or posts out of the way.
kenchan is offline
Old 05-21-2006, 09:58 PM   #12 (permalink)
J-Ro's Avatar
Jason
Okay, so it sounds like it's a similar setup to the headlights (i.e. a bracket that holds the bumper also holds back the light assembly). Fortunately I have lots of experience with the front of the car... now to take apart the back :)
Thanks for the help!
J
J-Ro is offline
Old 06-14-2006, 03:46 PM   #13 (permalink)
can someone make a DIY on this im also looking to tint my tail lights soon.
desi786 is offline
Old 06-15-2006, 10:31 AM   #14 (permalink)
J-Ro's Avatar
Jason
I'm going to be doing a "mission of discovery" as I call it, to prepare for an LED taillight mod, so I'll be taking the rear bumper off at some point. I can take some pictures while I'm at it and put something together.
J
J-Ro is offline
Old 09-23-2006, 12:06 PM   #15 (permalink)
J
Don't know if anyone has pictures of each of the bolts and clips that need to be removed, but any pictures would be great. I guess I will attempt it blindly if I can't find any step by step instructions and pictures and then I WILL take pictures of this so people in the future won't have as much frustration as I have had!
dpaschal is offline
Old 09-23-2006, 03:24 PM   #16 (permalink)
J-Ro's Avatar
Jason
Yeah, sorry... the LED array mod I wanted to do got mothballed because I found out the taillights cannot be heated up and taken apart like the headlights can, so I abandoned the project.
I did take some pictures, but I'm not sure if they're still on the camera... I'll have a look tomorrow when I get home.
J
J-Ro is offline
Old 09-23-2006, 04:09 PM   #17 (permalink)
Mission complete. My camera battery was dead, so pictures are a no go, but I will describe in detail...
There are four screws inside the fender well (no need to take tires off) that are holding the side of the bumper on. There are two plastic snap things just under the rear of the bumper that can be removed with a flat blade screwdriver. When you open the trunk, you will see the two hex bolts holding the rest of the bumper on. After all that is removed, just pull a bit on the sides of the bumper to disengage it from its recess. It will make sort of a ZZZZT noise.
After the bumper is off, you just have two bolts you need to loosen under each tail light and then there is 1 phillips head screw on the bottom of the tail light that needs to come out. If you have already removed the four plugs and the four inner nuts holding the light assembly, it will slide out with ease.
When you go to put the bumper back, make sure it goes in between the bottom bracket and tail lights and also you will need a rubber mallet to gently tap the sides of the bumper so it goes back into it's recesses.
That's about it!
dpaschal is offline
DIY Removing your bumper and Head lights. Paradoxblue Do It Yourself Articles 21 11-10-2007 12:37 AM
removing the reverse light cojaro Inside and Out 6 05-11-2006 03:32 PM
Removing panel under driver's footwell? J-Ro Inside and Out 6 05-03-2006 07:11 AM
Removing Vents on Si Streethonda06 Do It Yourself Articles 4 04-12-2006 10:57 AM
