Old 11-01-2007, 05:52 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Rob
how to remove fender?
I know I can figure it out; but before I get into it, how hard is it to remove the front fender on a coupe?
downwind4final is offline   Reply With Quote
Old 11-06-2007, 03:17 PM   #2 (permalink)
mishima8's Avatar
Not hard at all. There are some DIYs that include the instructions on the forum.
mishima8 is offline   Reply With Quote
Old 11-06-2007, 03:32 PM   #3 (permalink)
the bolts all look pretty easy at first glance...I imagine you will have to heat up the undercoated part to separate it a little underneath
torch02si is offline   Reply With Quote
Old 11-06-2007, 05:34 PM   #4 (permalink)
Rob
I did a search and could only find how to remove the bumper. I think I found every bolt but the lower one by the door.
Bolts on top in engine bay, one by headlight, one in front of mirror behind black cover.
Old 11-07-2007, 02:36 PM   #5 (permalink)
mishima8's Avatar
Are you are talking about the aluminum piece under the bumper?
Old 11-07-2007, 04:09 PM   #6 (permalink)
Rob
No, the bumper cover
Old 11-09-2007, 01:38 PM   #7 (permalink)
mishima8's Avatar
You need to unscrew the two screws in the wheel well. There are two more under the plastic cover also. You need to pop that cover off and then another two clips on the trim that is on either side of the engine bay. Remove the clips under the car too, I think there are ten clips and two larger 10MM screws.Then you pull real hard and it should pop off.
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/63201-how-remove-fender.html
Do It Yourself Articles [Archive] - 8th Generation Honda Civic Forum This thread Refback 02-12-2008 09:55 PM
R18 NST pulley kit DIY el_ben2 Engine 154 10-08-2008 06:37 PM
Front Spring/Damper Removal/Install Highrev1 Suspension and Brakes 32 10-04-2008 11:09 PM
*DIY-HONDATA IMG Install-Q Style Qshooter151 Engine 249 09-28-2008 11:34 AM
quick: how to remove inner fender? falkon57 Do It Yourself Articles 9 02-25-2007 02:17 PM
