Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Suspension
Old 09-20-2007, 08:58 PM   #1 (permalink)
60103's Avatar
Ken
DIY Front Brake Pads
Another DIY for brakes
Front Brake Pad Replacement
Special Tools Required
Brake caliper piston compressor 07AAE-SEPA101
CAUTION: Frequent inhalation of brake pad dust, regardless of material composition, could be hazardous to your health.
-Avoid breathing dust particles.
-Never use an air hose or brush to clean brake assemblies. Use an OSHA-approved vacuum cleaner.
Replacement
1. Raise the front of the vehicle, and support it with safety stands in the proper locations.
2. Remove the front wheels.
3. Remove the flange bolt (A) while holding the caliper pin (B) with a wrench. Be careful not to damage the pin boot, and pivot the caliper (C) up out of the way. Check the hose and pin boots for damage and deterioration.
4. Remove the pad shims (A) and brake pads (B).
5. Remove the pad retainers (A).
6. Clean the caliper bracket (B) thoroughly; remove any rust, and check for grooves and cracks.
7. Check the brake disc for damage and cracks.
8. Apply a thin coat of M-77 assembly paste (P/N 08798-9010) to the retainers on their mating surfaces (indicated by the arrows) against the caliper bracket.
9. Install the pad retainers. Wipe excess assembly paste off the retainers. Keep any assembly paste off the discs and pads.
10. Apply a thin coat of M-77 assembly paste (P/N 08798-9010) to the pad side of the shims (A), the back of the brake pads (B) and the other areas indicated by the arrows. Wipe excess assembly paste off the pad shims and brake pads. Contaminated brake discs or brake pads reduce stopping ability. Keep grease and assembly paste off the brake discs and brake pads.
11. Install the brake pads and pad shims correctly. Install the brake pad with the wear indicator (C) on the upper inside. If you are reusing the brake pads, always reinstall the brake pads in their original positions to prevent a momentary loss of braking efficiency.
12. Mount the brake caliper piston compressor (A) on the caliper body (B).
13. Press in the piston with the brake caliper piston compressor so the caliper will fit over the brake pads. Make sure the piston boot is in position to prevent damaging it when pivoting the caliper down. NOTE: Be careful when pressing in the piston, the brake fluid might overflow from the master cylinder's reservoir.
14. Remove the brake caliper piston compressor.
15. Pivot the caliper down into position. Install the flange bolt (A), and tighten it to the specified torque while holding the caliper pin (B), with a wrench. Be careful not to damage the pin boot.
16. Press the brake pedal several times to make sure the brakes work. NOTE: Engagement may require a greater pedal stroke immediately after the brake pads have been replaced as a set. Several applications of the brake pedal will restore the normal pedal stroke.
17. After installation, check for leaks at hose and line joints or connections, and retighten if necessary. Test-drive the vehicle, then check for leaks.
60103 is offline
Old 07-30-2008, 03:06 PM   #2 (permalink)
SiAzul's Avatar
Mario
any difference with the back brakes? and how much would that compression tool cost?
SiAzul is offline
Old 07-31-2008, 01:13 PM   #3 (permalink)
They Call Me TK's Avatar
Troy
back pads are a lot different!!! you can use a c-clamp for the front no problem. the back requires you to twist the piston in with a tool you can pick up at any local auto store, it will look like a giant box with different ends, clockwise to twist the piston in and the pads will fit in the grove. you will also have to take off the e-brake lines on each side and remove the brake line bracket to make it work.
They Call Me TK is online now
Old 07-31-2008, 02:31 PM   #4 (permalink)
Teach me how to take pics
maximus20895's Avatar
Max
you can rent a compression tool at a auto store. You pay up front and then they reimburse you when you return it
P2R TBS/TBGs / Fujita SRI / Skunk2 10th Anv. Knob/Radiator Cap / TWM SS/ Auger Boot
TWM Cable/Base Bushings / StrutKing DP Cover / JDM Dipstick / Cleared Head/Tails /
My Car Build Thread - Amilia
maximus20895 is offline
Old 07-31-2008, 02:36 PM   #5 (permalink)
ēmuch FAP... overload
ryryninja's Avatar
205whp 147tq :D
Make sure to do the proper inbedding instructions listed on the box.
ryryninja is offline
Old 08-06-2008, 01:00 PM   #6 (permalink)
BSonly's Avatar
what about resuracing the rotors? a must or not?
BSonly is offline
Old 08-06-2008, 07:59 PM   #7 (permalink)
Troy
not unless the car wobbles when you brake
Old 08-06-2008, 08:04 PM   #8 (permalink)
[hwy]Hagen's Avatar
or you can use a C clamp those work fine
[hwy]Hagen is offline
Dumb Laws C2i0v0i1c Water Cooler 56 03-19-2008 03:02 PM
Price for Front HFP rotors and pads. CivicCoupe06 Inside and Out 0 09-08-2007 12:12 AM
Removing mud flaps and front and rear brake cooling vents...? Johnold Inside and Out 14 04-02-2007 07:20 PM
new brake pads at 25000 miles turktech Civic Coupe And Sedan 5 03-13-2007 08:34 PM
Brakes (06' Si) Parts-list: Torredo Suspension and Brakes 3 12-07-2006 01:59 AM
