Six eyes
![]() Join Date: Apr 2006
Jason
Removing stock brake lines?
Hi,
I'm having trouble removing the stock brake lines from my FG1. They come off the calipers fine, but I'm having a lot of trouble separating the soft line from the hard line where they join. I'm also not reefing on it because I don't want to screw anything up. If anyone can offer suggestions or pics it would be greatly appreciated! Thanks! Jason
I'm so JDM, my girlfriend is Japanese. 私はあまりにもJDMなので、私の彼女は日本人です。 |
When removing...Keep the stock lines completely intact (i.e. do not remove anything especially the clip where the bracket connects the hard and soft lines). After that you need to break the nut on the hardline side. Use a flare wrench. Once you hear the nut break loose, you can remove all other components and continue with the brake line replacement.
#3 (permalink) | |
Six eyes
Jason
) I think that's probably what I should be using.Thanks for the help!
For some reason the front passenger side is the worst. In one case, even a flare wrench would not do the trick. Instead, I had to use a vice grip installed really tight in order to remove without stripping.
#5 (permalink) | |
Six eyes
Jason
![]() Well I'll ask my boss tomorrow for a flare wrench. He's big into cars and will probably have it. I found another quirky thing... when taking the lower caliper piece off, the lower mounting bolts were much more difficult to get off than the top, for all four calipers..... who knows ![]() So needless to say, yesterday I had to admit defeat, skip the lines, and flush and bleed the system with the stock lines still on. Unfortunately I don't have another car to get me around, so since my car's going in for an alignment tomorrow, I may get them to do that at the same time. Thanks for your input anyway!
Six eyes
Jason
Okay I got the nuts off successfully.... one more question: are the rear lines permanently attached to the brackets where they connect to the hard lines? If so, what do I do for installation of the new lines? Leave the bracket out completely?
Thanks!
#7 (permalink) | |
#8 (permalink) | |
Six eyes
Jason
Thanks again!
#10 (permalink) |
Six eyes
Jason
Really? Mine don't. The rears have the same fitting as the fronts, i.e. the clip-style..... I'm starting to get confused... do you have any pictures?
#12 (permalink) |
Three times a charm...For the rear lines, the bracket is attached in the stock setup. For the replacement lines, the bracket is separate from the hose (mine are Russell SS lines). Here is a PIC of the rear:
![]() As you can see, I used two clips on this side (topside of the bracket) and two clips on the rear on the other side. One clip that came with the Russell lines and the stock front clip. Doubling them up helped to secure the line to the bracket itself. I know that the CorSport lines are a little diffenent than the Russell ones, but you should be able to figure it out. |
#14 (permalink) |
Six eyes
Jason
Okay, thanks for the info. Maybe I'll just fabricate my own brackets
![]() *EDIT* You must spread some Reputation around before giving it to blueroadster again.
| Solution to more bass with stock system... | unplugged | I.C.E., Electrical, Security, & Navigation | 6 | 01-19-2008 11:39 PM |
| Bone stock Si puts down 188 whp!!!! | 954K20_SI | Civic SI | 36 | 07-04-2007 06:39 PM |
| The Si is a 14 sec car stock, list up videos etc | TreeFrog | Civic SI | 5 | 12-07-2006 10:49 PM |
| dealer pissing me off - brake noise after B maintenance | NoMoreHonda | Mechanical Problems & Technical Chat | 11 | 10-23-2006 10:15 AM |
