Old 03-19-2008, 07:46 PM   #81 (permalink)
I think I will do this mod too :)
mengy007 is offline
Old 03-19-2008, 08:13 PM   #82 (permalink)
Donald Trump FTW!!!
fiji06si13's Avatar
Justin aka Mr. JT
Pretty much my setup but I didn't remove the bellows in intake....
You used a turbonator? why ....All you did was put a big restiction in the airflow...
here is the link to my setup......
Homemade Icebox Intake
fiji06si13 is offline
Old 03-23-2008, 08:28 AM   #83 (permalink)
You have answered your own question, air restriction makes ecm reduce fuel required to combust. Hence less fuel used and you get more mpg.
bioevolve is offline
Old 03-23-2008, 09:52 AM   #84 (permalink)
Donald Trump FTW!!!
fiji06si13's Avatar
Justin aka Mr. JT
yes but you loose performance as well....
why would you spend all that time making the Intake less restictive and then add a restiction you just canceled out everything you did.....you made a performance mod just to counter act it?
There is tests that were performed on the Turbonator and the results are not good alot of the cars tested had worse performance then before it was put in....I'm not trying to mock you setup just trying to help....remove it and I promiss you will see better results
Old 03-23-2008, 12:20 PM   #85 (permalink)
02SilverSiHB's Avatar
yeah, seen yours..it's good for the coupe since you guys have that area for the fogs.
02SilverSiHB is offline
Old 03-24-2008, 07:11 PM   #86 (permalink)
It gets removed during strip runs, but when I drive to work on the highway it's in to save on gas.
Old 03-24-2008, 07:17 PM   #87 (permalink)
Donald Trump FTW!!!
fiji06si13's Avatar
Justin aka Mr. JT
Ah now I completly understand
Old 04-06-2008, 11:53 PM   #88 (permalink)
Pulver 4 President
Nathen's Avatar
Nathen
i did this mod without the insert, but its the best DIY mod to-date. sounds awesome vtec'n. you using a K&N drop in yet? love mine
//Eibach//Ingall's//BuddyClub
//CorSport//K&N//Hawk//Coming Soon... C-T Engineering
Nathen is offline
Old 04-14-2008, 10:03 PM   #89 (permalink)
drfters13's Avatar
what kind of sand paper should be used? because i just brought out my intake that i had in the attic. so i'm going to try it out. do you think adding the tb spacer and crv pipe would be good?
drfters13 is offline
Old 04-18-2008, 12:58 AM   #90 (permalink)
ive started my air box... i'll post pics of the finished product off the car and on the car... should be pretty neat.. i kinda did this on my ej1 but i didnt cut off the fins.. and i did a little something different that i'mma incorporate with this intake..
joon joon is offline
Old 04-22-2008, 09:25 PM   #91 (permalink)
HondaEmp's Avatar
Me
Removed the resonator and finished all of the bottom box and half finished the top. The ivtec kick is def smoothed over some. Next is a K&N at some point.
HondaEmp is offline
Old 05-20-2008, 03:54 AM   #92 (permalink)
atp1559's Avatar
DIY vs T1R
...just wondering about the whole hydrolocking thing...it looks like the T1R intake has its inle in the same location as the homemade icebox (just forward-facing), so is hydrolocking going to be an issue or is the whole hydrolock thing blown out of proportion? Any help is appreciated...thanks
atp1559 is offline
Old 05-20-2008, 11:05 AM   #93 (permalink)
Pulver 4 President
Nathen's Avatar
Nathen
the scoop/tube would have to be completely submerged for it to be an issue.
Nathen is offline
Old 05-20-2008, 01:55 PM   #94 (permalink)
atp1559's Avatar
thanks...did this on my 96 GS-R and never had any problems. Doing the mod today
atp1559 is offline
Old 05-25-2008, 09:44 PM   #95 (permalink)
sasebonian's Avatar
Jason
I am doing this mod now. I've had the K&N drop in for a while now and since it was Memorial weekend I had some time free to try this. I only had time to do the bottom portion though, as I have to go to my cousin's graduation party. I didn't have any silicone left over, but I did have a big metal hose clamp to use. I tried shaking and pulling it out to test the strength, and it holds great. I made sure the plastic didn't pinch or bend from the tightness of the clamp. Thanks for this. I am thinking about modifying the bottom portion like somebody else did so that it looks like the T1R version inlet, but since I have a 4dr Si, I don't have that extra air comming in from the fog spaces like the 2drs or JDM/CDM ones do. I plan on doing the top/air box tomorrow. Thanks for this DIY.
Next phase: Top/Airbox mod as stated by OP then CRV tube
sasebonian is offline
Old 05-26-2008, 11:47 PM   #96 (permalink)
Robstunner's Avatar
did this today. seems like theres a little bit of boost in performance. still hear vtec, and still hear the intake as before. works great tho.
Robstunner is offline
Old 05-26-2008, 11:51 PM   #97 (permalink)
Riverak21's Avatar
Kevin
Did this today as well. Now I need to hollow out the airbox itself....
I got tired of the K&N SRI I had and I also got tired of the whole intake game...
Wish there was some sort of dyno sheets for this. I don't have the funds but I have a RH so there would be no baseline.
Riverak21 is offline
Old 05-27-2008, 01:05 AM   #98 (permalink)
sasebonian's Avatar
Jason
Update: I smoothened out the top of the airbox. Man that was a pain in the @$$ as far as time goes. I had a dremel but not the long thin pencil like attachment which would have helped. Getting it smooth to where there were no more pieces of plastic sticking out was a long time to do. I am leaving the the 2 plastic vaines for the MAF alone though.
Old 06-09-2008, 10:51 PM   #99 (permalink)
i did this mod yesterday!
it was pretty easy and straight forward
i took off the bumber, driver side tire and the inner wheel well
i probably didn't need to take all that off..but hey it was good practice for my future mods
fightcity is offline
Old 06-25-2008, 06:39 PM   #100 (permalink)
jasonskater's Avatar
Jason
I want to do this but i dont want my vtec sound to go away =[
any more elaboration on the vtec sound dissapearing? i dont have an exhaust is it because the exhaust is louder or something?
jasonskater is offline
Dumb Laws C2i0v0i1c Water Cooler 56 03-19-2008 03:02 PM
just in case you need every cereal type from the 80's webby Water Cooler 16 12-09-2007 03:28 PM
