Old 02-16-2007, 05:45 AM   1 links from elsewhere to this Post. Click to view. #21 (permalink)
Dwn4nythng's Avatar
NorCal Meet Organizer
Did you remember to disconnect your positive wire from the battery and let it sit for 5 minutes then reconnect? If you didn't do that yet, you should. Don't forget to grab your code for the radio too, so when you start your car, you can type in the code to the radio and make it work again.
Originally Posted by dowNNshift
Tony -- Thanks for the kind words! Yeah this intake kit is night-and-day better sounding than stock! I had the same, WOW, when I took it out those first times too.
At mid-range (3500 to 5000 RPM) I can occationally hear the raspiness too, usually only in higher gears at lower speeds. Fortunately after a tank or so your Si will settle down once the computer adjusts to the new increased airflow, then you'll notice the raspiness less.
I am pleased that after a month of use through a wide range of ambient temperatures (25 degrees to 68 degrees), those initial vibrations have become unnoticable now that everything has settled. Although when I clean the filter for the first time, I too will definitely be doing SiCop's dampening trick -- hopefully by then K&N will have a retro-fit available.
What kind of milage are yall getting? Every time I fill up, I tell myself that I'm gonna take it easy on this tank -- but then I get on a straight away and the urge to take it into VTEC takes over
K&N makes a great SRI -- definitely recommend to all!
Dwn4nythng is offline   Reply With Quote
Old 02-16-2007, 05:34 PM   #22 (permalink)
dawg super clean write up!!!
post some sound clips or vids so we can hear the
hehe
losboyfg6 is offline   Reply With Quote
Old 02-19-2007, 11:42 AM   #23 (permalink)
deleted
dowNNshift is offline   Reply With Quote
Old 02-22-2007, 12:33 PM   #24 (permalink)
deleted
Old 02-26-2007, 01:24 AM   #25 (permalink)
mikef1182's Avatar
Hey great write up and thanks for all the details and pics!!!! Now you got me wanting one of these bad boys.
mikef1182 is offline   Reply With Quote
Old 03-04-2007, 01:04 PM   #26 (permalink)
46&2's Avatar
any idea of what the power gain over stock is?
46&2 is offline   Reply With Quote
Old 03-04-2007, 11:19 PM   #27 (permalink)
According to the K&N website it estimates 10.2 HP @ 6950 RPMS.
Another thing, are you sure this product works with the 07 models b/c when i search on the K&N website for 07 products only a replacement filter and oil filter appears?
Siwhiteboy is offline   Reply With Quote
Old 03-04-2007, 11:20 PM   #28 (permalink)
heres a link to the item on the K&N website
http://store.knfilters.com/search/pr...Prod=69-1012TP
Old 03-05-2007, 06:08 PM   #29 (permalink)
deleted
Old 03-05-2007, 11:45 PM   #30 (permalink)
ahh thats good to hear after you wrote this up i bought it immediately b4 i knew if it worked with the 07...i was hesistant to buy a SRI or an intake for that matter bc i didnt wanna take out the resonator, reason being when i go to the dealer i could swap it out quickly and the PITA of taking off the bumper. But thanks to your post its gonna be easy to do...i hope considering im a newb.
Old 03-05-2007, 11:47 PM   #31 (permalink)
also, quick question: you always take the positive wire off first and put the negative wire back on last...right??
Old 03-07-2007, 12:44 AM   #32 (permalink)
hey downnshift did it throw any cels?
Old 03-12-2007, 02:41 AM   #33 (permalink)
rmfa's Avatar
Ronnie
Bump for answers...
Old 03-15-2007, 03:51 PM   #34 (permalink)
DrR10n's Avatar
RT
great DIY. i have a typhoon in my 02 civic ex. the only problem with the SI is that it looks like the intake is so deep in there. since k&n recommends cleaning it once a year, it would be a pain to have to take out the pipe and the shield just to clean the filter.
some of you are probably thinking "It's only once a year" but it looks like it would be a lot of work. i hope it isnt that way cuz i'd love to have another fipk for my si. comments?
DrR10n is offline   Reply With Quote
Old 03-15-2007, 07:15 PM   #35 (permalink)
bulletSisedan's Avatar
Jamil
umm its only once a year...... j/k
bulletSisedan is offline   Reply With Quote
Old 03-16-2007, 12:23 AM   #36 (permalink)
umm ill answer that bump since i already bought it and installed it...no cels here
Old 03-21-2007, 03:51 AM   #37 (permalink)
Ceto21's Avatar
ya i jus ordered mine today i get it on friday cant wait!!!any of u guys got a video of it?!! i wanna hear it
Ceto21 is offline   Reply With Quote
Old 03-21-2007, 12:42 PM   #38 (permalink)
rmfa's Avatar
Ronnie
You will LOVE it. I absolutlely LOVE mine. Just make 100% sure you DO NOT tighten the 'L' bracket down AT ALL. Leave it VERY loose. After you get everything aligned, you can start tightening it up after its installed.
Old 03-22-2007, 01:00 PM   #39 (permalink)
deleted
Old 03-22-2007, 04:33 PM   #40 (permalink)
DrR10n's Avatar
RT
Very much agreed -- keep those L-brackets loose and then hand tighten after you've gotten it in the engine bay, because you'll have to wiggle it in to connect the intake hose into the throttle-body.
DrR10n - After 3-months the filter has stayed pretty clean, but then again I keep my engine bay so clean you could eat off of it.. Once the whole assembly has been in your engine bay for a while, un-installing and re-installing for service is alot easier for two reasons, A. you know what to expect and B. all the rubber hoses have a 'memory'.
Absolutely no problems, no rattles, and it still sounds fantastic -- best aftermarket upgrade I've done. Added plus, averaging 27.5 to 28 MPG too which isn't bad for a car with a 23 city / 32 hwy EPA sticker.
Enjoy!
sweet! good to know. are you actually getting BETTER mileage with the FIPK?
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/25230-k-n-short-ram-intake-diy-install-si-pics.html
K&N Short Ram Intake DIY Install for Si, with Pics! - 8th Generation Honda Civic Forum This thread Refback 12-26-2007 12:41 AM
DIY: Injen CAI install on R18 (lots of pics) peliROJO Engine 120 02-03-2010 02:27 AM
DIY: Install guide for OEM fogs... SonicK20Z Lighting 931 01-08-2010 08:30 PM
Civic Front Speaker install PICS (56K Get an upgrade) Mobieus I.C.E., Electrical, Security, & Navigation 12 07-21-2008 07:27 PM
How to install heat shield intake gasket and bypass TB coolant on 06 si. 06redsi Civic SI 30 08-16-2006 11:20 PM
Unplugged Racing Short Ram Intake unplugged Intake & Spacer Discussion 74 06-04-2006 11:03 PM
