Old 12-14-2006, 01:15 PM   #1 (permalink)
definingmoment's Avatar
Meh
Removing backs of seats
Does anyone know how to remove the seat backs?
definingmoment is offline   Reply With Quote
Old 01-28-2008, 11:03 AM   #2 (permalink)
I'd like to know to. Do you remove the back rest first? Where are the bolts?
Thanks.
yeba is offline   Reply With Quote
Old 01-28-2008, 11:52 AM   #3 (permalink)
Meh
Do you need to remove just the back? What for?
Old 01-28-2008, 11:59 AM   #4 (permalink)
Duce2k's Avatar
The sedan rear seat cushion has 1 10 mm. bolt that needs to be removed before the seat can be taken out, there are some clips at the bottom of the seat on the front side that you pull on to remove it after taking out the bolt, as far as the back rest I haven't removed that.
Old 01-28-2008, 01:22 PM   #5 (permalink)
Jeremy
same way to remove the coupe lower seat cushion, the bolt is just left of the middle, as for the backrest prtion id have to look in the manual for that
jeremy0203 is offline   Reply With Quote
Old 03-18-2008, 10:57 PM   #6 (permalink)
mrdimsum's Avatar
kelly
has anyone figured this out yet?
mrdimsum is offline   Reply With Quote
Old 03-20-2008, 03:21 PM   #7 (permalink)
MurderedCivic's Avatar
yes i have figured this out.... very easy... just took me a little while to figure it out in my friends NHBP si coupe... ok you unbolt the back rests first.. then you will have to unbolt the bottom second....this is a little tricky, you will need someone to hold (pry) the seat up while you slide your hands in the small spaces... i got to it from the trunk... then you will have to undo one bracket in the middle of the two seat...and then(stupidest part) the front of the bottom back seats is held down by 2 clips..... just exert some force on the front and the clips will just snap out...PITA !
MurderedCivic is offline   Reply With Quote
Old 03-24-2008, 01:00 AM   #8 (permalink)
naptown08si's Avatar
Ryan
dont let your friend break your seats either ^^^^^
naptown08si is offline   Reply With Quote
I'm getting heated leather seats (merged threads) Dizzle0420 Inside and Out 44 12-21-2006 04:43 PM
Leather seats?? strCIVIC Inside and Out 40 10-12-2006 08:04 AM
Honda vinyl protectant / seats caligold Inside and Out 0 10-03-2006 10:17 PM
Sparco Seats on the Si? type-si Inside and Out 11 06-20-2006 04:59 PM
leather seats??? psylenc2k Garage 3 05-26-2006 11:00 AM
