#67 (permalink) |
Done!
Just wanted to bump this old thread... I too have done this mod to my 08 HCH, but I used the module from a 2007 Odyssey that had Navi.
That means my module: - has working homelink - has a microphone in it to support the Navi - Has the interior illumination, which I changed to led to blue. Here's the proper pinout of the green connector... 1 - blank same as Civic. 2 - blank same as Civic. 3 - thin gauge pink (mic signal +) - goes to black wire on microphone 4 - thin gauge blue (mic signal -) - goes to green wire on microphone 5 - white/ blue - On Odyssey, this is Homelink + power, on Civic this is Mic white wire. On my setup I re-routed this mic wire to pin 9. For the Homelink power, I tapped inot to the overhead console light. 6 - black (ground) Homelink -, not used on Civic, so Civic harness needs this additional wire - run it to ground 7 - red/black stripe - (illum) + not used on Civic, so Civic harness needs this additional wire. I ran this lead to a illum wire on another button in the dash so the LED would be switched. 8 - blank same as Civic. 9 - blank - This is the pin I re-routed the pin 5 microphone lead to. 10 -ambient light ground. If you don't have Nav, ignore Pin 3,4 and 9 Just run 3 wires: 5 - tap off the overhead illum wire 7 - run wire down a-pillatr and tap off the illum + wire 6,10 - to any ground point. Nice easy 30 minute mod... I have 2 leftover homelink modules from my testing (both gray)... one with a microphone (with Nav) and one without a microphone (without Nav). $90 and $70 delivered if anyone wants em. I'll even replace the orange led for a blue on if you want... |
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/21530-my-next-silly-project.html
| 8th Generation Honda Civic Forum | This thread | Refback | 01-10-2008 07:05 PM | |
| project | NorCalFG1 | Garage | 10 | 11-15-2006 06:21 PM |
| StarDust@Home project | peliROJO | Water Cooler | 1 | 08-04-2006 01:22 AM |
| The Degree Confluence Project | CameronJr9 | Water Cooler | 1 | 04-21-2006 08:32 PM |
| basketball hoop project | webby | Water Cooler | 12 | 11-04-2005 10:52 AM |
| TOV Project Si Update | jbbrann | Civic SI | 12 | 11-02-2005 09:32 AM |
