#2 (permalink) | |
Someone please correct this if in error. Thanks. ![]() |
re:
just a thought. i dont know if it would work. Run a relay full circuit relay from the drl to the headlights making the drl as the switch that would activate the headlights.
Dont really know alot about circuitry but i have a relay on my HID kit now that draws power straight from the battery and is activated by the stock headlight swtich....just a thought. |
^ for the fuse # just pop open the panel under the steering wheel and crawl under there. the fuse's should be to the upper left and read the legend it should say something like daytime lights. once you locate that you should use the fuse puller which is located in the engine bay fuse box(its under the cover) sorry if its confusing. ill check back if you have any questions
#17 (permalink) |
errr! i really want to do this...
ok well heres a mayb, is there a way to have your fogs on while your Hibeams are on? if that is possible, ill just drive with my hibeams on whenever i can. i want to buy nokya 9005 yellows Last edited by Ep3racer954; 12-30-2006 at 11:16 AM. |
#20 (permalink) |
Okay well on the original topic,
DRLs are just (usually 30%) reduced powered high beams. Often you can see the high beam indicator on faintly on other cars. So, all you need to do, is keep you high beams on - and run a switch into the high beam output wire so that you can reduce the wattage at your will. |
| Wiring DRL's to run while headlights are on | riceracr99 | Garage | 11 | 11-01-2006 01:01 PM |
| Any of you had your headlights retroed from Retro-Solutions? | joonoo | Lighting, H.I.D.'s, & Neon | 1 | 08-21-2006 05:37 AM |
| New Headlights and Taillights | tronvex | Lighting, H.I.D.'s, & Neon | 8 | 08-09-2006 10:58 AM |
| ANYONE use or know about Vertex Racing headlights? Any good ? for 06 civic | coach2fast | Garage | 8 | 07-18-2006 01:35 AM |
