Old 05-21-2007, 08:29 PM   #21 (permalink)
Quickkidd's Avatar
so no one knows how to have both the DRL and low beams on at the same time?
Quickkidd is offline
Old 05-21-2007, 08:33 PM   #22 (permalink)
Quickkidd's Avatar
bump
Old 05-21-2007, 09:38 PM   #23 (permalink)
______
ethlar's Avatar
there was another thread like this i had posted a theoretical solution:
take a volt meter and determine the voltage and amperage going through fuse #37. get a switch, and find a source that runs the same amperage and voltage and run it through the fuse. in theory when you turn on the switch it would activate your DRLs whenever you wanted.
you could also remove the fuse and place an equivalent fuse in line with the source and run it into the cold side of the fuse.
ethlar is online now
Old 05-25-2007, 01:15 AM   #24 (permalink)
EntropyXIII's Avatar
i really want to know how to do this too. i think it would look cool with yellow bulbs and HID's kinda like the itr's...
EntropyXIII is offline
Old 05-30-2007, 02:00 PM   #25 (permalink)
bump for a solution....
the_civic is offline
Old 05-30-2007, 02:07 PM   #26 (permalink)
CrAsian's Avatar
i don't understand the point of having the drls and lowbeam running at the same time. more light? aesthetics?
CrAsian is offline
Old 05-30-2007, 02:10 PM   #27 (permalink)
inyong1988's Avatar
Junction Produce
I might disconnect my drl...it looks ugly....
inyong1988 is offline
Old 05-30-2007, 03:36 PM   #28 (permalink)
______
ethlar's Avatar
i gave you a solution, theres no reason why it shouldnt work
Old 06-12-2007, 11:04 PM   #29 (permalink)
so...has anyone tried this yet???
Old 06-12-2007, 11:22 PM   #30 (permalink)
Photographer/VFX Designer
MindFusion FX's Avatar
Jose
Originally Posted by fa1
Where's the dude that made the remote controlled sunroof and remote controlled window roll?:)
benmuger is the username to the only person i know that did that.
MindFusion FX is offline
Old 06-12-2007, 11:25 PM   #31 (permalink)
goofygamer's Avatar
Originally Posted by Tybeedon
Don't believe this is possible because the DRLs function is just a matter of low voltage being applied to the High-Beam bulb filaments. When you turn on the headlights with the switch, you then toggle between Low- and High-Beam settings. AFAIK, the DRLs have a separate fuse and by removing it you can eliminate the DRLs being "On" entirely.
Someone please correct this if in error. Thanks.
So if you have H.I.Ds as your high beam, then your DRL will run using the H.I.Ds? or will the relay trigger it not to turn on?
goofygamer is offline
Old 07-20-2007, 12:01 AM   #32 (permalink)
hey everyone i figured it out. i will have pics and a crappy diagram posted up soon. it looks really good but the high beams are still kinda bright so i think im gonna put in another resistor...
Old 08-23-2007, 10:38 PM   #33 (permalink)
Tim
any luck with this....
SiTim is offline
Old 08-23-2007, 10:49 PM   #34 (permalink)
______
ethlar's Avatar
yes
DIY: DRL's on with low beams
Old 04-03-2008, 11:00 PM   #35 (permalink)
i have my drls on wit my low beams. im running 8k hid and i put a switch for my drls, so now when i turn on my low beams, my switch my drls on. so now i got both of them on. so i switch out the oem bulbs, and put in super yellow blubs so i would have the look of the itr headlight. i not a big fan of fog lights on a sedan so i did that instead. its pretty easy to do. but only if u know about the wiring. pm me if u really want to do it. ( i also got black housing projectors for my headlights.)
yungbuks9i6 is offline
Wiring DRL's to run while headlights are on riceracr99 Garage 11 11-01-2006 01:01 PM
Any of you had your headlights retroed from Retro-Solutions? joonoo Lighting, H.I.D.'s, & Neon 1 08-21-2006 05:37 AM
New Headlights and Taillights tronvex Lighting, H.I.D.'s, & Neon 8 08-09-2006 10:58 AM
ANYONE use or know about Vertex Racing headlights? Any good ? for 06 civic coach2fast Garage 8 07-18-2006 01:35 AM
