Nacho Cheese!
Help with PQI 4GB SD card
I'm not sure if this is the right area, but I hope someone can help. I just bought a PQI 150x 4GB SD card and when I plugged into my computer, the capacity is only showing as 955 MB. I checked PQI's website and called their tech support, but it didn't really help. I'm thinking I either need to install something so Windows will recognize the full capacity or there's a problem with the card and it's not really 4GB. Does anyone have a PQI flash memory card that has heard of this?
San Jose's First Modified R18
I think this should be in the Technology forum, but I'll see if I can help anyway.
Try putting in the SD card and looking at it in My Computer. Right click the "drive" and go to Format. It should show you the capacity of the SD card (which should be around 3.xx GB in the first drop down box, but check to see if there are other options). You can try formatting it (if there's nothing on there or it will erase anyway), but I'm not sure if it will increase your capacity space. Give it a try and if it doesn't work, give PQI a call or return it for another one. Hope this helps |
#3 (permalink) | |
Nacho Cheese!
Ur soul. I haz it.
Disciple of Discord
It could either be an issue with the driver that runs your SD card reader or a problem with the card itself. Do you have another computer and reader you can test the card on? That should tell you for sure.
#6 (permalink) | ||
Nacho Cheese!
PQI is a cheap crappy brand. I used to work at frys electronics, and had nothing but trouble with returns on pqi. When it came time to get a 4GB chip for my car, i bought a patriot high speed 4gb CF, not sd. It reads the full chip fine. Usually its a compatibility issue with the chip and reader.
| Navi card reader problems | lampshadehead | I.C.E., Electrical, Security, & Navigation | 72 | 05-24-2007 04:29 PM |
| Only 512mb pc card works??? | djdefcon | I.C.E., Electrical, Security, & Navigation | 2 | 08-25-2006 06:17 PM |
| How do u use the pc card? | Mechanical Problems & Technical Chat | 6 | 08-03-2006 06:04 PM | |
| Need a little help with my pc card please | mmm def | I.C.E., Electrical, Security, & Navigation | 7 | 04-18-2006 02:28 PM |
| Nav Card Reader & File Organiztion | Jaranath | I.C.E., Electrical, Security, & Navigation | 3 | 04-14-2006 03:54 PM |
