#102 (permalink) | |
I was at work and I tried doing the keys lost function and reprogrammed all the keys and still no luck. I went into the HDS and tried to see if the unit could even pick up the signal from the key and still nothing. I checked the frequency id on the keys of a few models on the lot and the one that matched was a ridgline.I went on ridgeline owners club and yes they have already done this and it actually works for them !!!! So now the only option left to to find a switchblade key from acura that uses the same frequency as ours. TL-S key ............FCC ID OUCG8D CIVIC SI KEY .......FCC ID N5F-S0084A Pretty much S.O.L for me I guess at least i have another spare lol |
#103 (permalink) | |
#104 (permalink) |
Student of Photography
Nichuma Ben Gabriel Ha Levi
i second that! it looks sweet! even says honda and looks OEM. u can get the sticker from blue rocket with the H on it too :) i need a new key anyway..and cant find my extra mine has scratches all over it lol
#105 (permalink) | |
#106 (permalink) | |
______
#107 (permalink) |
aznkp, what do you mean they only have 2 button set ups? how about this one
HONDA SWITCHBLADE REMOTE KEY CONVERSION CASE 4 BUTTON - eBay (item 350015314533 end time Feb-13-08 19:27:18 PST) |
#108 (permalink) |
Beware:
I used the Ebay flip key for my Euro Civic and noticed that the transponder must be removed from the original board. Please check here fore more info: Who wants a flip key? - Page 17 - Civinfo and Who wants a flip key? - Page 16 - Civinfo stef |
#109 (permalink) |
looks like they all got it to work. ill register on the site later so i can view the attatched pics though.
thanks for the links! |
#110 (permalink) |
______
Stef, i saw one of your posts on that forum, the transponder is connected to the microcontroller so that the remote gets programmed at the same time as the immobilizer transponder, the transponder can be programmed connected or disconnected. However if your remote needs to be reprogrammed it wont be able to be done unless you reconnect the transponder.
#111 (permalink) |
After some research , which i should have done before wasting money . The 07-08 mdx key I located online uses the same FreQ ID and IC as the 8th gen civics. Now this might help all of us I.E the civic owners that don't need the trunk option. The one I located is a 2 button setup which is used for lower model mdx's that don't use the power tailgate option. I'm gonna assume that Ex and Si owners with the trunk option would want the 3 button setup from the fully loaded MDX. I'm gonna order the key tomorrow and go from there hopefully i'll have better luck.
07/08 mdx key w/power tailgate option p/n = 35111-STX-306 07/08 mdx key without tailgate option p/n = 35111-STX-305 Last edited by Millcitytech; 02-14-2008 at 05:03 PM. Reason: more info |
#112 (permalink) | |
that works too, even better! |
#113 (permalink) | |
Go BUCKS!
#119 (permalink) |
Just programmed the 07-08 MDX key and it works but only problem is the trunk option does not work . Lock and unlock work with no problem , so i guess thats better then nothing . I can live without the auto trunk option .If you guys can live without it then this is a possible route . Gonna do some more research and see if they have a switchblade key for the acura CSX .
