#90 (permalink) |
Has anyone seen this? HONDA SWITCHBLADE REMOTE KEY CONVERSION CASE 2 BUTTON on eBay, also, Honda, Car Parts, Cars, Parts Vehicles (end time 13-Feb-08 06:27:22 GMT)
EDIT: More info here -> Who wants a flip key? - Page 17 - Civinfo ***If posting the above information is not allowed. Please remove it. Thanks Last edited by kodath; 02-08-2008 at 01:44 PM. |
#92 (permalink) | ||
______
As best i can tell, short of physically cutting up and jamming the electronics of your civic key into an rdx/tl key, it unfortuntely will not work. I sat and traced out the wire traces on the circuit boards of the RDX key and the Civic key. As part of the Type 6 programing method, the transponder is on the chip of the Civic key and is connected to the main microcontroler chip. On the RDX the two leads which would be connected to a transponder are not connected to anything. The rest of the wiring appears to be fairly identical |
#93 (permalink) | |||
Go BUCKS!
Also, in this thread on ClubRSX, a Honda Master Tech describes all of Honda/Acura's immobilizer systems and says that Types 5 and 6 are identical in build, and only different in function, differing only in the sequence of the transponder check, like you mentioned. Quote:
#94 (permalink) | |
______
it wont program with hds, ive had 2 seperate dealers try with my rdx key, another member has tried twice with his TL-S key, it wont work. Immobilizers program but the remotes wont |
#95 (permalink) |
Go BUCKS!
Damn. I have already tried the TL-S key, and was hoping the RDX key would work. Thanks for the info though.
Do you think that thread posted above on the Civinfo boards provides any new info? In case you can't tell, I really want to figure this out! ![]()
#96 (permalink) |
I just programmed my TL key today and I'm also running into the same problem as everyone else . I can program the immobilzer to start the vehicle but the transmitters will not get picked up by the Vehicle, so my lock and unlock buttons and also trunk button is useless. Tomorrow i'm gonna try the all keys lost option on the HDS at work and see if that works. Sucky thing is the member that stated he did that also said the trunk option did not work (kind of odd ), if the lock and unlock worked then the trunk option should also work . Also another thing i was thinking of was cross referencing the keyless entry control unit and see if i can use the accord one instead to see if that works . I'll let you guys know the result tomorrow .
#97 (permalink) | |
Ride Of The Month
ing it will one day |
#98 (permalink) |
Wow, the conversion kit looks really good. They have a 3 button set up for ex/si too. 14.99 pounds = about $30.00, and shipping is free. Best case scenario, RDX/TL keys are $25 plus shipping and still dont work. Has anyone actually bought this conversion kit? I just bought one, it should be here in about 14 days. I guess we'll see when it gets here.
#100 (permalink) |
actually......
HONDA SWITCHBLADE REMOTE KEY CONVERSION CASE 2 BUTTON on eBay, also, Honda, Car Parts, Cars, Parts Vehicles (end time 14-Mar-08 06:27:22 GMT) its been done on Who wants a flip key? - Page 17 - Civinfo post 337 hmm..... downside... its only two button. which makes ex/si owners not be able to use the trunk button or something like that on that line |
