LinkBack (4) Thread Tools Display Modes
Old 09-20-2007, 03:48 PM   #61 (permalink)
rmfa's Avatar
Ronnie
Originally Posted by ethlar
it looks like it might come down to desoldering a component or two off of a already programmed key and transplanting it onto the RDX key to get the keyless to work
Hrm, sounds like a job. Keep us posted +1 rep
rmfa is offline
Old 09-20-2007, 04:17 PM   #62 (permalink)
drfters13's Avatar
so does the trunk release work? i have a after market alarm so i don't need the keyless entry on the civic key. do you have pictures?
drfters13 is online now
Old 09-20-2007, 04:26 PM   #63 (permalink)
______
ethlar's Avatar
The RDX has no trunk release button, and pictures of both remotes are posted earlier in this thread
8thCivic FAQ
ethlar is offline
Old 09-29-2007, 12:21 AM   #64 (permalink)
Cornizzy's Avatar
Cornell
i wanna know the outcome.. thanks
Cornizzy is offline
Old 11-17-2007, 09:05 PM   #65 (permalink)
Got RDX Key Fob To Work On 07 Civic
Since I work For Valley Honda I had some spare time today to try this out. I went to Acura and purchased two keys. A TL and RDX, I cut the RDX with the key machine and then took it and the HDS out to the car.
The hard part was following the directions after multiple attempts to program the key I finally did it. The secret was telling the HDS ALL KEYS LOST. This erases all the keys and fobs and then reprograms all the keys and fobs. Since I left my valet key at home I have to redo this process again so make sure you have all the keys with you when you do this. There is a step during the key relearn process that tells you to click the lock buttons of all the key fobs.
After doing the relearn process all keys and key fobs work with car. The only sucky thing is the no trunk button. . . which I'm working on trying to figure out. Good Luck
FA1user is offline
Old 11-17-2007, 09:24 PM   #66 (permalink)
slimfit's Avatar
Nice!! Keep us updated.
slimfit is offline
Old 11-17-2007, 09:37 PM   #67 (permalink)
udumkid's Avatar
Rene....
ummmm,why would you do it that way? I mean why did you select "all keys lost" option on the hds?
udumkid is offline
Old 11-17-2007, 09:42 PM   #68 (permalink)
I tried all other options an none of them would allow the fob to operate.
FA1user is offline
Old 11-17-2007, 09:47 PM   #69 (permalink)
udumkid's Avatar
Rene....
You do know the procedure to program the fob right?
udumkid is offline
Old 11-17-2007, 09:54 PM   #70 (permalink)
The standard key on . . . press lock button . . .key off repeated 4 times the lock twice does not apply to the 06+ civics they have Type 6 immobilizer not type 5 therefore the only way to program the key fob is with the HDS.
FA1user is offline
Old 11-17-2007, 10:02 PM   #71 (permalink)
udumkid's Avatar
Rene....
funny thing is that I re-programed a key just yesterday for a 06 civic ex and programed the key less entry with out using the HDS.
Ps- type 5 (or t5) immobilizer keys have a separate remote for keyless entry. T5 have been used on 01-05 civics.
udumkid is offline
Old 11-17-2007, 10:29 PM   #72 (permalink)
______
ethlar's Avatar
So you have the unlock/lock/panic buttons working on the RDX remote on your car? When they programed my remote they got the immobilizer working, but the remote wouldnt take the program after several attempts.
What method did you use to program the key without using HDS.
I have another spare civic key to hack up and either transplant the electronics or actually desolder the components and move them
8thCivic FAQ
ethlar is offline
Old 11-17-2007, 10:37 PM   #73 (permalink)
udumkid's Avatar
Rene....
udumkid is offline
Old 11-17-2007, 10:46 PM   #74 (permalink)
______
ethlar's Avatar
Im not sure how that answers my question as to how you managed to reprogram the keyless without using the HDS.
8thCivic FAQ
ethlar is offline
Old 11-17-2007, 10:55 PM   #75 (permalink)
udumkid's Avatar
Rene....
You dont need the hds to program the keyless entry(key FOB/keys with remotes built into them). There is a special procedure you have to follow in order for the FOB(keyless entry/remote) to work.
udumkid is offline
Old 11-17-2007, 11:03 PM   #76 (permalink)
______
ethlar's Avatar
could you tell me what that procedure is?
8thCivic FAQ
ethlar is offline
Old 11-17-2007, 11:20 PM   #77 (permalink)
dingdong's Avatar
Have you tried it with the TL key? or is it only going to work with the RDX key
dingdong is offline
Old 11-17-2007, 11:21 PM   #78 (permalink)
udumkid's Avatar
Rene....
pm'd
udumkid is offline
Old 11-18-2007, 07:42 AM   #79 (permalink)
chok's Avatar
Sirichok
Well,...
I am in Thailand and got the problem when I was programming the US Civic Ex key to my CIVIC'07. The key can start the engine and run (immo is good) but the remote is not work (The same problem with ethlar on RDX).
So I was wondering that if "FA1user" or anyone could give me a suggestion on following point.
* Does the US key use the different frequency from my key?
* Is the correct procedure important to program the key?
FA1user; It would be nice and useful if you could explain the detailed procedure to program the key with HDS so I could bring it to the dealer.
Thank you
chok is offline
Old 11-20-2007, 05:48 PM   #80 (permalink)
Any luck with the procedure???
av911 is offline
LinkBacks (
