#223 (permalink) |
I bought an MDX key, had it cut, and this morning I attempted to have it programed. They were able to program the Immobilizer, so I am able to start the car, but they said they can't get the keyless to work.
The first time they tried, they added the MDX key, that didn't work. Then they deleted my Master key, reprogramed that. Tried again with the MDX key, keyless still doesn't work. The service advisor was real nice and curious to see if it worked. He asked me to get some more information on it and let him know and he'll try to get this thing working. What options are left to get it to work? - I'm thinking it's because of the Link/Unlink on the MDX key. I pressed both the lock and unlock to link and unlink, but I can't tell if it's linked or unlinked. - Or have them delete all keys, including the Valet key, and reprogram it. - I didn't think of this at the dealership, but maybe they were using the iPaq instead of the HDS Tablet?? Thanks in advanced!!! |
#225 (permalink) | |
#227 (permalink) | |
So, the next step I should do is: 1. Have them update the software, turn off FOB memory and reprogram it again. 2. If that doesn't work, delete all keys and start over. ?? |
#232 (permalink) |
is it impossible to get the truck to open and if so why?
![]() P2R TBS/TBGs / Fujita SRI / Skunk2 10th Anv. Knob/Radiator Cap StrutKing DP Cover / JDM Dipstick / Cleared Head/Tails / Auger Boot My Car Build Thread - Amilia |
#233 (permalink) | |
Any chance you can provide the programming procedure? They wanted me to drop by tomorrow and give it another go. Thanks!!! |
#237 (permalink) | |
CIVIC KEY: FCC ID : N5F-S0084A IC : 3248A-S0084A MDX key W/ tailgate option: FCC ID : N5F-0602A1A IC : 3248A-0602A1A I checked today at work and the 2 button LX key fob has the same FCC ID and IC freqs as the SI and EX key FOBS. So there is no reason why it shouldn't work. Just make sure the seat memory is off , Connect the HDS tablet to the DLC connector with vehicle on, Put in all pertenant info such such as mileage and model for the most part it will automatically do this.Then in the menu select Immobilizer. From this point select add key.... and the technician will perform the precedure after the procedure the HDS will ask the technician to program key FOB. It will display the question " Is this a switchblade Key FOB " . The technician will then click yes and then it will say when next screen displays click the lock or unlock button on the key fob and nothng else. Once the next screen is displayed and he does this the door lock with cycle o engage indicating that the key fob is programmed. I stress that he has to click lock or unlock and not both at the same time or one then the other. Just one button will suffice. after that it will ask to register key and after that point the key is now registered in the ECM/PCM and your done. Sorry to drag this on but this is a very simple process. We update our HDS whenever one is available , hopefully this dealership does the same . Good luck with your programming and let us know what happens. |
#238 (permalink) |
Thank you for the detailed information!!!
I did check the FCC ID and the IC and the first part of those numbers are the same. I really think it was because of the memory seat. Now that it is unlinked, it should work. I'll let you know what happens. |
#240 (permalink) | |
