kaixen install help - 8th Generation Honda Civic Forum
Old 11-15-2006, 02:40 AM   #1 (permalink)
t1ny's Avatar
kaixen install help
does anyone know where to plug in the extra fuse that came with the kit because im clueless.. plz someone help thank you
t1ny is offline
Old 11-15-2006, 03:49 AM   #2 (permalink)
The extra fuses are useless. I got the Kaixen kit as well and the included ones do not fit for the low beam headlights (left and right). You will need to go to your dealership and ask for 2 of the "20" lowbeam headlight fuses.
Tri3Dent is offline   Reply With Quote
Old 11-15-2006, 04:10 AM   #3 (permalink)
t1ny's Avatar
those fuses goes under the driver console rite?.... or is it the fuses box under the hood
t1ny is offline   Reply With Quote
Old 11-15-2006, 04:19 AM   #4 (permalink)
t1ny's Avatar
can u tell me the number that is labeled as the headlight fuses and i need 2 to replace the 10a fuses rite?....
Old 11-15-2006, 01:18 PM   #5 (permalink)
PoLiShPrInCe's Avatar
pics of the kaixen hids please? this is the kit that im going to get
PoLiShPrInCe is offline   Reply With Quote
Old 11-15-2006, 02:31 PM   #6 (permalink)
t1ny's Avatar
i dun have any pictures atm but im still having trouble.... i replaced the fuses with a 20amp for the right and left labeled under 16 and 17 where the steering wheel is inside the car.... any other help??? i pretty dam sure i put the connections on correctly......
Old 11-15-2006, 09:54 PM   #7 (permalink)
Yea, the fuses for the lowbeam left/right is inside..... I don't remember what number they were but I know it's in the middle..
Not sure if it's the same for US models but the fuses are the mini mini ones.. It seems like stores around here have never heard of such mini mini fuses.
So that's why I had to go back to the dealer to get the special mini mini fuse for the lowbeams.
Are you having problems turning the HIDS on?
Here is the picture of the kit:
The packaging looks very classy so it seems really good from the start. After you install it, it looks good as well!
Old 11-15-2006, 10:30 PM   #8 (permalink)
looks good... so u have to replace fuses when installing these things?
Old 11-15-2006, 10:52 PM   #9 (permalink)
Izzy's Avatar
That's what I'm wondering. In any kit that I've seen, they give you a spare fuse for the relay harness, and that's it.
Old 11-16-2006, 02:44 AM   #10 (permalink)
t1ny's Avatar
GOT IT TO WORK.... just replaced the fuse and had to change up the wiring~!~! yeah will ahve pics up soon
thankz for the help guys
Old 11-16-2006, 03:46 AM   #11 (permalink)
the thing of replacing the fuses is because the factory provides you with 10A fuses (which is not enough power), so you will need replace them to something higher, 20A. Or else you will be finding yourself replacing fuses every week.
RafF is offline   Reply With Quote
Old 11-16-2006, 03:55 AM   #12 (permalink)
Yea.. the HIDS uses more power so using 10A fuses will burn every week or so.. so that's why they supply you the 20A ones.. but they don't work for the 8th gen civics (uses different type of fuse instead)..
Lets see those lights!
BTW, what did you get? 6500K? 8500K?
I got the 8500K
Old 11-16-2006, 04:41 AM   #13 (permalink)
I got the 8500K
The HIDs use more power at first when you just turn it on, but afterwards, it uses less power compare to halogen.
Old 11-16-2006, 04:44 AM   #14 (permalink)
lol yea, that's what i mean... uses more power when it ignites
Old 11-16-2006, 01:00 PM   #15 (permalink)
Izzy's Avatar
I assume there's no other relays connected to the ballast then? I only asked my previous question because, as I said, my relays usually have the 20A fuse built in.
Old 11-28-2006, 05:37 PM   #16 (permalink)
James
There are spare fuses located in the fuse box in the engine bay. I am pretty sure there is at least 1 20a fuse in there. At lease it will save you a trip to the dealership for now.
slimjim8481 is offline   Reply With Quote
Old 11-28-2006, 05:41 PM   #17 (permalink)
James
How are those lights. I have heard reviews (not of those but other plug and play HID systems) that they use cheap ballasts and after a while they start to flicker or dont start up right away. How long have you had yours installed and are they working good? Thanks
Old 11-29-2006, 01:23 AM   #18 (permalink)
Works fine so far. No problems. But I only had it for like a month but it's been working great.
DIY * Injen CAI install * Si 06blaksi Mechanical Problems & Technical Chat 281 08-16-2008 05:18 PM
Problem with Pioneer P880PRS install nuked99 I.C.E., Electrical, Security, & Navigation 2 11-13-2006 12:24 AM
How do I install the HPF front lip for the 06 Si CIVI7 Civic SI 2 09-18-2006 03:32 PM
IMG install?!? SonicK20Z Intake & Spacer Discussion 1 06-21-2006 06:45 PM
