Serpentine Belt - 8th Generation Honda Civic Forum
Old 03-09-2010, 09:44 PM   #1 (permalink)
Eric
Serpentine Belt
Hi all, does anyone know when we should change the serpentine belt on civic 06-10? Every 100,000 kms? Also, I tried searching for a serpentine belt DIY, but couldn't find ine, does any one have a DIY serpentine belt?
thanks in advance!
ericivic is offline
Old 03-10-2010, 04:40 AM   #2 (permalink)
andrew
not sure about the intervals, i changed mine at around 90,000 it started fraying on one side...if it looks and sounds ok its prob still good
oneeightseven is offline   Reply With Quote
Old 03-10-2010, 08:01 AM   #3 (permalink)
gotsnodooks's Avatar
Russ
changing the belt is pretty easy...just put a wrench on the tensioner to loosen it and when routing the new one just pay attention to the routing of the belt. It's a lot easier than it may look. I also found it helpful to jack the front of the car up so you can get to the lower pulleys easier.
gotsnodooks is offline   Reply With Quote
HOW to install serpentine belt imvusa Mechanical Problems & Technical Chat 14 06-01-2011 07:49 PM
Serpentine Belt civic si mierzwa2 Mechanical Problems & Technical Chat 31 09-27-2010 07:29 PM
Serpentine belt jdmcoupe Bolt-Ons And All-Motor 0 07-19-2009 09:50 AM
Need Help Removing Serpentine Belt (Si)! redpepSi Mechanical Problems & Technical Chat 0 09-14-2008 04:16 PM
Serpentine Belt CNUco2007 Mechanical Problems & Technical Chat 3 12-31-2006 11:22 PM
