Greg
someone help with installing new pedals please
im trying to figure out how to install these pedals, and what the silver brackets are for. i assume you drill and screw them on? and theres bolts for the brake it looks like.. if someone has a link to a DIY or helpful advice it would be very nice
1. The 8 small screws are for the dead pedal and throttle. Use a screw driver.
2. The long screws along with the nuts and brackets are for the brake pedal. Put the long screw through the 4 holes above the brake pedal. Insert bracket with the L facing you. Hook this over your existing brake pedal. Thread the nut and tighten. Note: This is by no means the official installation method. It is the one I find most logical, though. My main concern is the brake pedal, the hook and clamp does not seem like a very sturdy way to mount the faceplate. If I were you, I would tighten the bolt securely and give each nut a drop of locktite. Note #2: I hope this is a replica product, b/c I'd be mad if this was an official mugen product. I'd stick with the strutking pedal set, a bit pricey but well worth the near OEM like quality. Last edited by habitat; 02-22-2010 at 07:36 PM. |
#3 (permalink) | |
Greg
Greg
im returning this set, the dead pedal doesnt fit at all, its hanging off about 2 inches and about 2 inches too short as well, the brake clips are crap, didnt even bother trying to install. gonna get the strutking set everyone keeps talking about
^^ I'm sure the strut king set uses self tapping screws. Of course rivets would be more secure but if you don't already own one, it may not be worth it to buy a rivet tool when the screws will hold up just fine. A cheaper alternative to rivets is a dab of mild locktite and the supplied screws.
#9 (permalink) | |
Jonathan
| Si Pedals | bry | Inside and Out | 30 | 02-17-2009 09:01 PM |
| si pedals | Bman825 | Inside and Out | 16 | 01-22-2009 02:37 PM |
| Aftermarket pedals | Exit | Inside and Out | 1 | 09-15-2006 02:21 AM |
| Pedals | jbswads | CorSport | 10 | 06-18-2006 10:33 AM |
