What requires alignment after work - 8th Generation Honda Civic Forum
Old 02-21-2010, 10:15 PM   #1 (permalink)
Hey folks,
I was wondering what jobs usually require a front end alignment after the job is accomplished?
Some examples:
- a strut replacement
- tie rod end replacement
- ball joint replacement
- CV Joint
- wheel bearing
Thanks!
ourkid2000 is offline
Old 02-21-2010, 10:16 PM   #2 (permalink)
I've totally put this in the wrong forum!
ourkid2000 is offline   Reply With Quote
Old 02-21-2010, 10:18 PM   #3 (permalink)
B MAN's Avatar
Brian
almost everything that u touch the suspension
i know after a shock replacement u need an alignment
B MAN is offline   Reply With Quote
Old 02-21-2010, 10:35 PM   #4 (permalink)
soxfan143's Avatar
Not always. It depends on suspension design. With the older accords and civics that had the multi-link front suspension and the front strut that had the fork at the end that mounted to the lower control arm did not necessarily require an alignment after replacing the strut. The only 2 jobs that absolutely require an alignment after completion are your inner and outer tie rods.
This question is only answerable based on what model and year of the vehicle.
For our Civics if you replace the front struts, inner or outer tie rod, Steering rack, rear lower control arms, rear upper control arms or parts similar to that.
soxfan143 is offline   Reply With Quote
Old 02-21-2010, 11:27 PM   #5 (permalink)
I should have mentioned this.....sorry!
I have a 2006 Civic LX Coupe
Old 02-22-2010, 09:05 PM   #6 (permalink)
Also, you pretty well can't do your own alignments can you?
Probably best left for the shops. My question, I suppose, is if you replaced your own strut would it be alright to take your car to the shop on another day?
Old 02-22-2010, 09:17 PM   #7 (permalink)
Ya most definently.....The car may pull and/or the steering wheel may be off-centered a little but itll be fine. Just dont wait to long or you might end up damaging your tires by causing them to wear improperly.
K20Z3Sedan is offline   Reply With Quote
Old 02-27-2010, 10:47 AM   #8 (permalink)
Setting the toe yourself isn't very difficult. If you are capable of replacing your own strut, then you can probably set the toe yourself. You just need a tape measure and some flat plates, or even string. Then measure across the car in front and behind the wheel. The difference is the toe out or toe in. If you get it down to 1/8" or less by turning the tie rods, then you won't have to worry as much about abnormal tire wear. If your steering wheel is turned to one side, then you adjust one tie rod more than the other to bring it straight again. Setting the camber or castor yourself requires more equipment and an extremely flat floor to work off of.
cravej is offline   Reply With Quote
Where to get alignment armenakadino California South 16 07-07-2009 05:14 AM
Alignment Question Zephbane Wheel And Tire Upgrades 0 05-12-2008 11:02 PM
alignment dnbsi Garage 7 02-09-2008 12:06 PM
Alignment or what? SIcivic07 Mechanical Problems & Technical Chat 14 01-21-2008 01:09 AM
alignment off? pwrful4 Wheel And Tire Upgrades 3 11-11-2007 12:55 AM
