DIY: Making a Shift Knob (56k, No Way) - 8th Generation Honda Civic Forum
Old 01-13-2010, 04:44 PM   #1 (permalink)
Fleet Admiral's Avatar
Warren
With this method you can make a shift knob out of any thing you want. You can also most likely use this method to make a knob you have sit lower (like the S2 knob).
If you decide to watch the video please read the text tutorial also because I said the wrong tap size.
I chose an 8ball because it's what I had lying around and I wanted to see if I liked the feel of a ball shaped shifter. It's also softer so tapping it was fairly easy.
Ok, you need a drill, an 11/32 drill bit(or 8.7mm), a 10 x 1.50 tap, a marker or some sort, and the knob.
This is what the tap looks like. You can get them from about any hardwear store.
So mark the ball.
Then drill a hole. Make the hole as deep as you want. I recommend making it over an inch so it sits as low as possible and just use the locking nut. (If you're attempting to make a shift knob you already own sit lower, drill into the hole that is already there carefully and slowly to prevent jacking the threads that are already there. KEEP THE DRILL STRAIGHT! I suggest using a vise to prevent the drill bit grinding on the inside of the already threaded hole.)
Now you want to tap the ball. You insert the tap and slowly tun until you get the tap into the ball a few millimeters and make sure it's straight so your threads don't get jacked. Then wind the tap down into the hole clockwise until it's too hard to turn. Start twisting counterclockwise until it's almost out. Twist back down and repeat, speeding up the rate of twisting each time. When the tap screws in and out verrrrry smoothly you can stop this process and it should be done.
Happy tapping!
Fleet Admiral is offline
Old 01-13-2010, 04:47 PM   #2 (permalink)
BLK_FG1's Avatar
DONT do this with a golf ball. Drilling golf balls can be VERY dangerous.
BLK_FG1 is offline   Reply With Quote
Old 01-13-2010, 05:01 PM   #3 (permalink)
ojefferyo's Avatar
Jeff
did you learn that the hard way
ojefferyo is offline   Reply With Quote
Old 01-13-2010, 05:01 PM   #4 (permalink)
Warren
Originally Posted by blk_fg1 View Post
dont do this with a golf ball. Drilling golf balls can be very dangerous.
lmfao
Fleet Admiral is offline   Reply With Quote
Old 01-13-2010, 05:17 PM   #5 (permalink)
BLK_FG1's Avatar
no, but ive heard some pretty bad stories.
Old 01-13-2010, 07:04 PM   #6 (permalink)
H07si's Avatar
Thomas
Nice DIY.
im scard to make my shift knob sit lower though. I dont want to mess up the thread inside of it
H07si is offline   Reply With Quote
Old 01-13-2010, 07:07 PM   #7 (permalink)
Warren
As long as the bit is the right size, it shouldn't. Try using a 11/32 bit by hand, if it doesn't fit in no problem, then try an 8.7 mm.
Old 01-13-2010, 07:09 PM   #8 (permalink)
SiAzul's Avatar
Mario
nice, that looks guud
SiAzul is offline   Reply With Quote
Old 01-13-2010, 07:17 PM   #9 (permalink)
p1904's Avatar
Micho Rizo
nice.
p1904 is offline   Reply With Quote
Old 01-13-2010, 08:07 PM   #10 (permalink)
Midnight Run's Avatar
nice!!
Midnight Run is offline   Reply With Quote
Old 01-13-2010, 08:08 PM   #11 (permalink)
F1R3B411's Avatar
David
what happens? makes me want to try it... hehe
F1R3B411 is offline   Reply With Quote
Old 01-13-2010, 08:08 PM   #12 (permalink)
CrazyQuady's Avatar
looks good, might have to try this.
Golf balls are like a rubber band ball on the inside (kinda) they can explode basically.
CrazyQuady is offline   Reply With Quote
Old 01-13-2010, 08:20 PM   #13 (permalink)
Warren
It's just hard to drill into a golf balls because of the dimples.
Old 01-13-2010, 08:21 PM   #14 (permalink)
CrazyQuady's Avatar
exploding golf balls just sounded better
Old 01-13-2010, 08:23 PM   #15 (permalink)
F1R3B411's Avatar
David
so drilling a golf ball is "VERY dangerous" because of the dimples?
Old 01-13-2010, 08:27 PM   #16 (permalink)
B MAN's Avatar
Brian
someone post video of what happens when u drill into a golf ball
B MAN is offline   Reply With Quote
Old 01-13-2010, 08:28 PM   #17 (permalink)
B MAN's Avatar
Brian
It was a danger when the golf balls had liquid centers with a rubber band wrapping. This put the liquid under pressure.
Now golf balls are solid, and the only danger there is in holding them while drilling.
Old 01-13-2010, 08:31 PM   #18 (permalink)
Dar-Dar's Avatar
Darwin
Nice DIY there. I might give this a try for fun, but Idk what to drill. Lol.
Dar-Dar is online now   Reply With Quote
Old 01-13-2010, 08:46 PM   #19 (permalink)
Glen_PxC's Avatar
Glen - R18 Crew Member #2
now I'm curious....why is it dangerous to drill into a golf ball?...
Glen_PxC is offline   Reply With Quote
Old 01-13-2010, 09:21 PM   #20 (permalink)
YouTube - golf ball bomb(the best ever)
This guy drilled out golf balls. I was so curious I started searching for it. Awesome DIY by the way.
ridenrunwv is offline   Reply With Quote
DIY - Automatic Shift Knob Replacement Cr8tive_leo Interior Style Mods 273 02-04-2012 07:37 PM
DIY: insulated shift knob midnitesi Interior Style Mods 69 01-26-2012 10:13 PM
DIY: Removing the R18 shift knob (MT) splew Interior Style Mods 32 01-25-2012 02:00 AM
New Shift Knob and Shift Boot! (PICS 56K Go climb Everest) ImTheVoiceOfGod Introduction & Pictures 25 05-27-2011 11:40 PM
making a shift knob (specs?) cambodianricer Mechanical Problems & Technical Chat 17 01-20-2008 02:50 AM
