How to replace spark plugs 06 si - question - 8th Generation Honda Civic Forum
Old 01-10-2010, 07:58 PM   #1 (permalink)
Hi,
I searched the forums but couldn't find a good how to about removing the cowl so I can get to the spark plugs on my 06 si. I have 120k on the orignal plugs and figured its time to change them. I founds so pics on-line that show the cowl cover with it's 6 clips and 6 hoooks. When I look at the car, I see the 3 clips that are in front but no others. I removed the clips, along with 2 others that shouldn't be part of the cover but do connect to the cover that I'm trying to remove. I can pry the cowl cover up but it still seems attached. I just don't see the other clips. Anyone have a clear photo or good directions about what else to remove? I appreciate it!
Chuck
cjdock is offline
Old 01-14-2010, 02:04 AM   #2 (permalink)
Moderator
|-Goku-|'s Avatar
Here's a Thread about removing the Valve Cover, but also shows how to remove the Cowl to get to the Cover.
Hope it helps
DIY: Valve Cover Removal...
|-Goku-| is offline   Reply With Quote
spark plugs civicstona21 Inside and Out 16 01-13-2010 01:43 AM
What spark plugs do you use? darocker80 Bolt-Ons And All-Motor 22 05-25-2009 04:44 PM
Spark plugs for 06 Si IcemanSiNYC Civic SI 1 04-15-2009 04:47 PM
Replace spark plugs yet? Civic2006 Civic Coupe And Sedan 4 12-10-2008 12:59 PM
Spark Plugs jeremy0203 Forced Induction And Nitrous 10 01-02-2008 06:12 AM
