Issues with Skunk SS - 8th Generation Honda Civic Forum
Old 01-09-2010, 01:45 AM   #1 (permalink)
si2k7's Avatar
<FG2FREDDY>
i just tried to install my Skunk2 Short shifter in my 07 fg2. i followed all instructions and even had someone else check it. i could not get it into like 2nd or 4th cause it was hitting the plastic piece under. it was in as far as it went in. can anyone help me out with some info. thanks!
<supfred>
si2k7 is offline
Old 01-09-2010, 01:55 AM   #2 (permalink)
Zeuceone's Avatar
Grind off some of the plastic.
Old 01-09-2010, 01:57 AM   #3 (permalink)
Ruthless909's Avatar
Ls1 JeRk
Ruthless909 is offline   Reply With Quote
Old 01-09-2010, 02:05 AM   #4 (permalink)
si2k7's Avatar
<FG2FREDDY>
it wont screw anything up? is this a common problem??
si2k7 is offline   Reply With Quote
Old 01-09-2010, 02:55 AM   #5 (permalink)
beeroge1020's Avatar
Bryson
<supfred>
do you know what plastic piece it's hitting? i haven't heard of this problem before but i know when i first installed mine it wasn't sitting properly so i couldn't get it in 2nd or 4th. make sure the ball is all the way in the adapter and that you tighten the allen screws all nice and tight.
beeroge1020 is offline   Reply With Quote
Old 01-09-2010, 04:04 AM   #6 (permalink)
si2k7's Avatar
<FG2FREDDY>
exactly its not going into 2nd and 4th...its hitting the plastic piece at the bottom. its where the linkage cable is i guess. it looked like it went all the way in but maybe not. what im noticing on other threads are the adapters seem wider that the skunk one. idk
Old 01-09-2010, 12:22 PM   #7 (permalink)
MattyJay88's Avatar
Jersey
are you sure its pushed all the way on?
MattyJay88 is online now   Reply With Quote
Old 01-09-2010, 12:55 PM   #8 (permalink)
si2k7's Avatar
<FG2FREDDY>
yes i even took it off and did it again.
Old 01-09-2010, 01:03 PM   #9 (permalink)
wicked image's Avatar
Bill
i have installed a few of these on 07 Si's. i had the same problem with one of them where i couldnt get it to clear. i found it was user error in being that one of the little screws was in just a tiny bit. so my advise is to take the screws out far enough to where they arent falling out but close to then push it on. if this doesnt work then you will be forced to trimming the plastic to make it work. hopefully this helped
wicked image is offline   Reply With Quote
Old 01-09-2010, 01:03 PM   #10 (permalink)
Will06SI's Avatar
RPM_FURY!!
Ive had no issues on my 06 SI with it go over the entire install again maybe on the 07's its a little diff in that area but overall you should be fine..
Will06SI is offline   Reply With Quote
Old 01-11-2010, 01:08 AM   #11 (permalink)
si2k7's Avatar
<FG2FREDDY>
ok i re-did the whole process over again and had no luck! the SS would not clear the plastic piece. i had to grind down the piece in order to clear. after some elbow grease i got it done! it clears 2nd, 4th, 6th and reverse!! feels pretty good.thanks for the info!!
Old 01-13-2010, 03:38 AM   #12 (permalink)
P Slyce
<supfred>
I had the same problem with my first CorSport unit, turns out it was improperly machined, which made the shifter throws really really short, and popped out of 5th all the time) I suggest trying an identical part before buying a new one, or atleast shoot Skung a letter
-FreuderLocks
Monsterbishi is offline   Reply With Quote
Old 01-21-2010, 02:13 AM   #13 (permalink)
si2k7's Avatar
<FG2FREDDY>
Ya after i filed down the plastic piece it was all good...shifts ll good and doesnt pop any gears out...
Old 01-21-2010, 02:31 AM   #14 (permalink)
a1rfreshener's Avatar
mike
yea i just grinded it off ...
a1rfreshener is offline   Reply With Quote
Skunk 2 SS E2EK1E7 Bolt-Ons And All-Motor 6 09-13-2009 11:12 PM
Anyone with Strutking SS issues? jmann Mechanical Problems & Technical Chat 3 09-26-2008 09:08 AM
TWM SS vs. Comptech SS vs. All other SS Si Speed 317 Bolt-Ons And All-Motor 63 11-28-2007 08:03 PM
Skunk 2 Shift knob w/ ss? krndodo Bolt-Ons And All-Motor 20 01-18-2007 05:00 PM
