DIY:Ipod Custom Mount
This is for a 2010 Honda Civic LX-S
02 Jan 2010---Hard wired this tuneflex ipod dock so that it can be hooked up to the factory 12 volt outlet ![]() Drilled hole out bigger to accommodate the power wires. ![]() Added a switch with blue led.Then testing it out before installing in the Civic. ![]() Cut out the panel to accommodate the dock.It goes in the place of the pocket behind the shifter. ![]() Cut out for the dock and switch today.Snapped the cover from the shifter off to see how it fit.Taking the four hex head screws out that holds the pocket on.Not using this ,but using the screws for later to mount the new panel.Need to round the edges off a little more.Looking good so far. ![]() Got the vinyl this week and got my stuff together to cover it.Hd staple gun,hammer,razer knife,contact cement,brush, heat gun. ![]() Started on one of the long sides and worked my way around.Heated the corners up a bit to help stretch it. ![]() Finished covering,and it turned out pretty good. ![]() Cut some slits For the switch and the dock.Using an O-ring for trim around the dock. ![]() Had to stretch the o-ring a bit to make it fit snug.Covers up the blimishes. ![]() Got some picture hangers and bent them to mount the panel . ![]() Mounted the wiring for the dock with ring loop holder. ![]() Prewired the connection I will be using.This will be hooked up to the power outlet.No cutting of factory wire. ![]() Hooking up the connections to the power outlet. ![]() Using the existing 3.5 connection from factory.I may still want to use my Ipod out of the dock . End result,Jamming to some Rush. ![]() One more picture.
Going to order some vinyl this weekend then.Found some that looks to match the shifter pretty good.Hope to get it done by next week end.I'll edit my DIY then.
Thanks Oh what does subd mean, for the old slow guy.
#15 (permalink) |
Thanks guys, I haven't been up here in a while,I want a sub one day,just don't know when I will get one.I had JL Audio subs when I was into the music big time.Worked at a stereo store in Kinston,N.C.for about 8 years then.That was 23 years ago though
#18 (permalink) |
James
that actually blends in really nice.. do you have any trouble with the iPod staying put when you take a corner really hard/slam on the brakes/hit a pot-hole/etc?
also, do you have any way of changing tracks besides using the iPod control? |
| DIY: Harman & Kardon Drive & Play ipod kit, cheap gps unit mount. | mixadell | Do It Yourself Articles | 13 | 04-03-2009 03:26 PM |
| DIY: Harman & Kardon Drive & Play ipod kit, cheap gps unit mount. | mixadell | Do It Yourself Articles | 0 | 06-29-2008 12:30 AM |
| Custom Ipod Holder DIY | NewbTuner | I.C.E., Electrical, Security, & Navigation | 1 | 08-11-2007 10:58 PM |
| Custom IPod install, IPod set ups. | Knight-Rider | Inside and Out | 6 | 01-29-2007 10:33 PM |
| iPod mount? | Mikes A D | I.C.E., Electrical, Security, & Navigation | 13 | 05-08-2006 11:23 PM |
