Hids - 8th Generation Honda Civic Forum
Old 12-29-2009, 04:08 AM   #1 (permalink)
sonko91's Avatar
Hids
Im installing HIDS for my 09 Si is gonna suck, gotta take off the bumper and tires. Any one no any easier way?
sonko91 is offline
Old 12-29-2009, 04:12 AM   #2 (permalink)
Stephen
My HID DIY with before and afters
b17hatchback is offline   Reply With Quote
Old 12-29-2009, 04:14 AM   #3 (permalink)
Low&slow installed my HIDs and didnt take off bumper or tires, well kinda of removed a few bolts from the bumper to get his arm in.
SlightInterest is offline   Reply With Quote
Old 12-29-2009, 11:30 AM   #4 (permalink)
K
i have a 2010 FA i put in the hid and didn't took off the bumper.. just take of the bots from the bumper for your hand to go in..!!!
gatito is offline   Reply With Quote
Old 12-29-2009, 11:36 AM   #5 (permalink)
it just BLOWS my mind
vtecGOD's Avatar
Frankmaistersauce
Who takes his Bumper off to install HIDs???
Unless you are doing your Fogs
vtecGOD is offline   Reply With Quote
Old 12-29-2009, 11:36 AM   #6 (permalink)
bueno4x4's Avatar
Bueno
^seconded
bueno4x4 is offline   Reply With Quote
Old 12-29-2009, 11:39 AM   #7 (permalink)
vtecGOD's Avatar
Frankmaistersauce
Originally Posted by b17hatchback View Post
This DIY makes it look hard!!!
Old 12-30-2009, 05:00 AM   #8 (permalink)
hids
just put hids in wit my dad. hes ase cert. mechanic. i did not take my bumper off. the driver side is easy. just take out the battery and radiator overfill bottle and u have plenty of room to swap the bulbs and mount a ballast. the pass sde is harder. because of the ABS unit with all its hardlines coming out of it, its a tight fit. i reccomend getting someone with small hands and wristsfor this. you have to remove the windsheild washer bottle. just carefully pull off the 1 plastic clip holding it in. then the top portion of it will sep. from the lower and this will beleive it or not create enugh room tochange the bulb on the pass side. i had a hard time with the power connector for te bulbs. make sre you push the connectors in hard. i almost thought i had a bad set of bulbs before i realized that was the prob.
bluebare915 is offline   Reply With Quote
Post up your HIDs... asdf Lighting, H.I.D.'s, & Neon 1705 02-10-2012 01:31 AM
hids jdmfg208 Lighting, H.I.D.'s, & Neon 5 04-26-2009 11:41 PM
Hids Installed With Pics But Not Sure If The Hids Output Came Out Properly donjuanle Ontario 11 10-07-2008 10:02 PM
New HIDs Doug Lighting, H.I.D.'s, & Neon 11 01-18-2008 03:27 PM
My HIDs wing_gundam Lighting, H.I.D.'s, & Neon 21 04-14-2007 12:31 AM
