DIY Install for KBCarstuff LED Halo Projector Headlights - 8th Generation Honda Civic Forum
Old 12-27-2009, 11:43 PM   #1 (permalink)
FattyMcJ's Avatar
Jason
DIY Install for KBCarstuff LED Halo Projector Headlights (56k go make a sammich)
I didn't see a DIY like this for the site sponsor brand LED Halo projector headlight install, so I thought I'd make one. If it's a duplicate, go ahead and delete it.
06-07 HONDA CIVIC 4DR Xenon Headlight, Performance Headlight, Racing Headlight, Aftermarket headlight, projector headlamp, Euro Headlights, halo, lo Headlights, Angel Eye Head Lights, LED, HALO
These are the Headlights I purchased from our site sponsor Xenon Depot (KB Car Stuff)
Okey dokey, I'll start off with the assumption that you all know how to take off the front bumper. Do that...
You should be here:
Note the duct tape holding on the foam bumper thingy...don't break off the top tabs like I did
Now grab that 10mm socket and start here:
It's handy to have a REALLY long extension for your socket...10" roughly.
Now, normally this part would be attached to the headlight housing (pic is upside down view)...but some douchebag in an SUV decided to back up into my headlight and broke it clean off:
In your case, just use the 10mm socket and take the metal brace off the housing.
Unplug all 3 lights (High beams, Low beams, turn signals) and set the stock headlight aside.
And now for the replacement headlights:
Flip it upside down and re-use the stock turn signal bulb/plug in the new headlight.
Plug the three major plugs back in, and make sure everything works so far:
Now the fun part. You can wire the LED's and Halo's however you'd like, but I wired both to the turn signal power for ease and they'll always be on from parking light setting up to high beam setting. SAY NO TO DRL's lol
Stick the blue wire connector on the black turn signal wire, as shown, then connect the two BLACK wires from the Halo's and LED's to that. Clamp down, done. Do the same for the WHITE wires from LED/Halo to the RED wire on the turn signal. (Not shown...easy to figure out)
Again, test to make sure they work how you'd like:
If they work, put it all back together and rinse and repeat for the other side!
Your finished product should look similar to this:
Edit: Now I just have to figure out how to aim them...they're kinda pointing out like.... \_/ sorta instead of |_|.
FattyMcJ is offline
Old 12-27-2009, 11:50 PM   #2 (permalink)
penukoko's Avatar
nice diy thx
penukoko is offline   Reply With Quote
Old 12-28-2009, 03:31 AM   #3 (permalink)
Nice. I just ordered an HID kit from this company and am thinking the headlights might be next. How does the light output/visibility between these and factory compare?
ridenrunwv is offline   Reply With Quote
Old 12-28-2009, 03:57 AM   #4 (permalink)
FattyMcJ's Avatar
Jason
Well, stock bulb vs. stock bulb, the projectors are much cleaner. If you go driving at night, sure what's in front of you is "lit", but with these, just driving around the block to take pics, the light was much more focused. Nothing above the car was lit, but the ground in front was clearly visible. You can see the "cut-off" in the pic above.
Overall, I'm very impressed and happy with the purchase.
FattyMcJ is offline   Reply With Quote
Old 12-28-2009, 05:38 PM   #5 (permalink)
MattyJay88's Avatar
Jersey
Nice DIY, but not really feeling the lights.
MattyJay88 is online now   Reply With Quote
Old 12-28-2009, 05:59 PM   #6 (permalink)
FattyMcJ's Avatar
Jason
TY, and to each his own
Old 12-29-2009, 04:47 PM   #7 (permalink)
David87's Avatar
David
nice diy ty
David87 is offline   Reply With Quote
Old 12-30-2009, 03:38 AM   #8 (permalink)
f4remix's Avatar
can it fit w/ HID ? normal 9006 hid Kit? can u upload a pix for how it look in the day time ? thanks
f4remix is offline   Reply With Quote
Old 12-30-2009, 03:44 PM   #9 (permalink)
FattyMcJ's Avatar
Jason
I have an email in to XenonDepot/KB Car Stuff right now asking that very question. Their site says "10% off if you buy the headlights AND HID kit" and "get the full effect by using HID's" ... but there is a sticker on the unit itself that says "do not use HID's"...so who knows.
That and there was NO instructions/information/specs that came with these (in english). So everything I did, I had to figure out on my own lol.
I'll post what information I get as I get it. As for pics, I'll get some soon. It's been really crappy weather lately (you can see the piles of snow in the pics above) so a day shot right now wouldn't do them justice.
Old 12-30-2009, 11:17 PM   #10 (permalink)
IceMurder's Avatar
Chris
why would there be a sticker saying "Do Not Use HIDs?"
HIDs burn at a lower temperature than regular bulbs...
IceMurder is offline   Reply With Quote
Old 12-30-2009, 11:18 PM   #11 (permalink)
IceMurder's Avatar
Chris
and WOW they want 200$ for HIDs? lol
Old 12-31-2009, 02:32 PM   #12 (permalink)
FattyMcJ's Avatar
Jason
I don't know
Old 01-07-2010, 01:08 AM   #13 (permalink)
Niceeeeeeeeeeeeeeeeeeeeeeeeeeeee
KraZyOne is offline   Reply With Quote
Old 04-14-2010, 03:22 AM   #14 (permalink)
tony_routh88's Avatar
I know this is late in the game but just some food for thought, yes hids do operate at a lower temperature and voltage than stock headlight, but the sticker is referring to using hids with the wiring provided. The wiring on those headlights isnt sufficient enough to withstand the voltage peak when hids "fire up" so if you buy an hid kit, just ditch the wiring that came with the headlight housing and rig up the ones that came with the hid kit.
tony_routh88 is offline   Reply With Quote
Old 04-14-2010, 06:06 AM   #15 (permalink)
FattyMcJ's Avatar
Jason
Aahh, indeed. Thank you for the info.
However, I ended up returning these headlights due to the fact that they just wouldn't aim straight. Always like a "V" and that's just annoying, lighting up the sidewalk and oncoming traffic, not in front of my car.
Oh well, I now have HID's in the stock housings and couldn't be happier!
Old 04-16-2010, 05:09 AM   #16 (permalink)
Moderator
|-Goku-|'s Avatar
Would there be any reason why they don't have these for 2009 4/dr?
|-Goku-| is offline   Reply With Quote
Old 10-08-2011, 11:19 PM   #17 (permalink)
Great DIY! Thank you. Funny that I have the same aiming problem as you do + 1 of the head lights I bought is filled with humidity!!
Eagle29 is offline   Reply With Quote
Old 10-12-2011, 04:30 PM   #18 (permalink)
uchup's Avatar
Nice diy. can you use hid on the low beam slot?
uchup is offline   Reply With Quote
Old 10-14-2011, 08:23 PM   #19 (permalink)
FattyMcJ's Avatar
Jason
Yep, I ultimately had to return them. Not worth the money, unfortunately
No clue, never got that far with these things. I just went back to stock and have loved my HID kit in the stock housings ever since.
Old 10-27-2011, 05:02 PM   #20 (permalink)
Ku Moua
looks clean
moobmuas is offline   Reply With Quote
JDM LeD Halo Projector headlights FA5 graybully77 Lighting, H.I.D.'s, & Neon 5 04-27-2008 03:11 AM
Dual Halo LED Projector Headlights Fishstix Lighting, H.I.D.'s, & Neon 2 02-01-2008 05:36 PM
2006+ Honda Civic (2dr) LED Halo Projector Headlights (Black) unplugged Lighting, H.I.D.'s, & Neon 14 10-25-2007 09:54 PM
Halo LED projector help Rabbit Lighting, H.I.D.'s, & Neon 10 05-26-2007 10:52 PM
HONDA CIVIC 2 HALO BLACK PROJECTOR HEADLIGHTS LED CivicNewGuy Lighting, H.I.D.'s, & Neon 1 08-11-2006 04:09 AM
