Rob
I need Help with powering LEDs
Hi I've installed a bunch of LEDs inside my car (under the seats, under the dash, in the console and cup holders) I had them hooked up to batteries (two 9V batteries) but the Amps are too low to hold power to the lights for more than a minute, so I want to bridge power from the fuse box. I bought the "Mini add-a-circuit" but I don't know how to use it...I need help! how do I know how much amps to use since the thing can't use over 10 should I plug it in a 10Amp spot? and the fuse from the car seems smaller than the ones in the package does that matter if the adapter fits? I took pictures of what I 'THINK' is right...can you guys help me?
You don't just connect it to any fuse. You connect it to certain fuse according the when you want the LED to actually come on. For example if you want the light to come on when you turn your headlights on then you would tap it in to fuse 14 which is 7.5 amp.
Add a fuse is really simple to use just find the right fuse on the panel, replace it with the add a circuit with the original and new fuse on it. Then you will have the positive charge. To get the negative charge you just ground the other cable. |
9k everyday...
^^i'm sorry sometimes when i post i leave out the small details that most people over look.... thanks for clearing up my post....
i can't remember which fuse number i used to power the under dash lights...... i just remember it's one with constant power..... some spots only get power when lights are on or when the car is on....... thanks again Last edited by Lstarz14; 12-04-2009 at 11:40 PM. |
Rob
So I remove the 7.5amp fuse from spot #14 and replace it with the "add a circuit" with Two 7.5 amp fuses installed into it? so left over I have the stock fuse handy? (it won't fit in the space in the add-a-curcit) and any suggestions for the ground spot I don't wanna kick it by accident!
Rob
so basically i have the add-a-curcuit with a 7.5amp and a 10amp fuse in it, in the #14 spot for headlights...so 7.5amp will be for the headlights and the 10amp will be for the LEDs? so basically the LEDs have a 10AMP fuse on them?
| Powering LOC?? | JDMoore | Do It Yourself Articles | 0 | 10-12-2008 07:35 PM |
| Superbright leds - License plate leds | Dueces22 | Inside and Out | 10 | 10-25-2007 10:55 PM |
| Question about powering an amp | pirulo51 | I.C.E., Electrical, Security, & Navigation | 12 | 04-20-2007 10:38 AM |
| powering an amplifier | 2006silver | I.C.E., Electrical, Security, & Navigation | 3 | 08-02-2006 10:24 AM |
| powering the sub | pointbrink | Civic Coupe And Sedan | 11 | 03-26-2006 09:47 AM |
