n00b retro whore
Mirror tilt down on shift into reverse
I would really like a feature like this, i know bmws have it, and I was wondering if anyone else knew of a module that could be added to tilt the passenger side mirror down and in a certain amount when you shift into reverse and then put it back afterwards. Im going to continur to research and maybe try to figure it out to build one myself.
n00b retro whore
it will come back up when you shift out of reverse, the basic idea of the unit we are going to try to build is when you shift into reverse it would get a turn on signal and move the passenger mirror down for a set time to move the mirror down. when you shift out of reverse the unit would move the mirror back up the same amount of time it moved it down. so in theory it would put the mirror back exactly where you had put it.
Im sure we will discover something we missed once we actually build one and test it. As far as i can tell the Acura electronics are based on a memory system and the car has a way of sensing where the mirror is and has a set reverse position that it moves to and it can remember your position to return to. Our mirrors lack this and are just remote controled motors from the controls. |
#10 (permalink) |
better than curb feelers
#11 (permalink) |
lol @ curb feelers pic :) to think you wouldn't be able to park a miata...
i'm also interested in how your little experiment goes, it should be quite easy actually, like t-tapping the reverse light cable and running it into a relay for a timer circuit that trips another 2 relays for the up/down of the mirror... |
#12 (permalink) | |
GGMIKEY
| Civic 1.8L paddle shift in Singapore | tanwn | Civic Coupe And Sedan | 12 | 09-29-2006 10:51 PM |
| Does Augerresources shift boot fit Coupes? | joonoo | Inside and Out | 4 | 09-03-2006 06:21 PM |
| Voodoo Knob and Shift Boot Solution | Fixer | Inside and Out | 2 | 08-17-2006 10:38 PM |
| Shift boots | hoanger | Inside and Out | 10 | 06-20-2006 12:03 PM |
