DIY: SS clutch line - 8th Generation Honda Civic Forum
Old 07-02-2009, 11:02 PM   #1 (permalink)
FG-JOE's Avatar
Joseph
Arrow DIY: SS clutch line
Here is a DIY on changing the oem clutch line to a stainless steel braided.
tools used:
8mm wrench
10mm wrench
12mm ratch or impact gun
17mm wrench
flat head screw driver
piece of hose maybe about 1 foot long
1.first thing you want to do is remove your battey and platic peice under the battery.
2.remove the battery bracket, there are 4 12mm bolts holding it. 2 on top and 2 on the bottom holding it up.
3.heres a picture of what you'll be working with.
4.now you want to extract all clutch fluid as possible, i opened the bleeder with the 8mm wrench and had my asistant pump the clutch fluid out, next remove the resevior cap, and extract fluids from there aswell.
5.with a 10mm wrench, break loose the 2 bolts going into the line. dont remove them just yet!
6.with the 2 10mm bolts loosened... with a flat head screw driver, pull out the 2 clips holding the line, you will need some force.
7.after pulling out the clips,you can unscrew the 10mm bolts.
8.comparison of both items.
9.work the new SS clutch line in...place into the clip holders.
10.slide clips back in
11.screw in the 10mm bolts into the SS clutch line.when tighting the 2 10mm bolts, use the 17mm wrench to hold the SS line from turing.
over all the install was easier than i thought....took maybe about an hour tops to fully complete the install(includes bleeding)
here is the DIY on bleeding your clutch.
DIY Brake and Clutch Bleeding with Speed Bleeder Installation
FG-JOE is offline
Old 07-02-2009, 11:10 PM   #2 (permalink)
Admin Ninja
obert's Avatar
obert
Nice diy !!!!!!!!!!!
My Civic Feature On NW-Built
Old 07-02-2009, 11:10 PM   #3 (permalink)
PrEgO CaNe's Avatar
Brendan
so what exactly is the benefit of swapping lines? i understand the brake lines but don't get the clutch line.
PrEgO CaNe is offline   Reply With Quote
Old 07-02-2009, 11:11 PM   #4 (permalink)
FG-JOE's Avatar
Joseph
stiffer clutch pedal, this is my buddys car, he had a stage 2 clutch installed. i guess the oem line doesnt have that much pressure to work a higher stage clutch.
FG-JOE is offline   Reply With Quote
Stainless Steel Clutch Line AA07si CorSport 5 01-05-2009 08:37 AM
Stainless Steel Clutch Line? infiniti_4_life Clutch & Transmission 11 10-16-2008 03:09 AM
SS Brake line vs etd jpv027 Garage 2 12-03-2007 02:39 AM
SS Brake line DIY? polgas07 Do It Yourself Articles 1 05-15-2007 02:43 PM
