#121 (permalink) |
All the way down without the locking nut makes it HARD to shift, at least in comparison to a slightly longer throw axis. I prefer actually putting that lock nut all the way in the shifter...it sits a little too low, but the shifts are short and crisp without being hard to shift into the next gear.
#122 (permalink) |
Brian Ko
Just finished installing the base and cable bushings...def remove the center console it made it a lot easier...and those pins on the oem rubber cable bushings were mad annoying to take off...i just twisted them till they broke...overall easy install and very satisfied with the results
#123 (permalink) | |
8thcivic Sponsor
![]() Join Date: Oct 2005
Good to hear you got the bushings installed OK and that you're happy with the results ![]() Thanks for all the great feedback guys! Kevin TWM |
#124 (permalink) | |
#125 (permalink) | |
8thcivic Sponsor
Kevin TWM |
#126 (permalink) | |
8thcivic Sponsor
Check it out: TWM Shift Knob Sale Thanks, Kevin TWM |
#127 (permalink) |
vasi
I did the cable bushing first but couldn't tell there was a big difference. After i installed the whole kit SS and bushing( luckily i didn't run in any kinds of trouble...didn't have to take the center console of) the shift is shorter but the shift has to be more firm and there's sort of difference when putting it in reverse.
#130 (permalink) | |
Tom Smith
Not sure what you mean?? Personally, if I would do it again I would get the cable bushings and the short shifter but forget about the base bushings. They were a pain to install and I don't think really do all that much.
#131 (permalink) | |
Tom Smith
#132 (permalink) | |
#134 (permalink) |
I just wanted to emphasize that you should remove the console. It takes 2 minutes.
There are 6 attachment points: Two screws in the armrest compartment. You have to pull up the rubber mat to see them. Two screws that you see when you remove the shifter bezel. Two push pins in the footwells. Get them with a flathead screwdriver. The driver side pin is visible, to get the passenger side you have to pull off the lower dash panel. It pulls right off. I didn't even try to do it without removing the console, and I can tell I saved a lot of time. |
#135 (permalink) |
Traveling Road Show
![]() Join Date: Jan 2007
20Strong
I was wondering why my install didnt seem right I didnt get the socket adapter in my kit.
http://i135.photobucket.com/albums/q...g/20st5pz3.jpg |
#136 (permalink) | |
8thcivic Sponsor
Which part of the kit are you referring to when you say the "socket adapter"? PM me or give me a call at 1-877-655-0540 and we'll take car of any missing components. Thanks, Kevin TWM |
#137 (permalink) |
Mike Nguyen
I used the cup removal tool for the initial install. I didn't want to bend the plastic, so I put that on over the metal and put a wrench behind it and used that as a pivot. Worked out perfect.
#138 (permalink) | |
8thcivic Sponsor
Thanks, Kevin TWM |
#140 (permalink) |
Just installed twm short shifter.Holy ****berg the shifts are sweet if u want to save $ the short shift will do. i installed the base bushing and shifter bushing. Last week put in amsoil tran fluid had 21.000km and 3rd was getting tough to go in sometimes.Amsoil made a big diffrence!!!.But with the short shifter it is orgasmic.
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/16370-install-guide-twm-short-shift-kit-2006-honda-civic-civic-si.html
| Parking Brake Adjustment on 2006 Civic with Drum Brakes (Hybrid) - Honda Car Forum - Accord Parts Civic Tuning Acura Racing | This thread | Refback | 02-24-2008 05:18 PM | |
| Civic SI Sedan Comes To America - Chicago Auto Show Debut | webby | Honda Industry News | 11 | 04-19-2008 10:24 PM |
| 2006 Honda Civic Hybrid Pricing Released | webby | Civic Hybrid | 0 | 11-30-2005 11:08 AM |
| 2006 honda world news | webby | Garage | 0 | 07-25-2005 10:31 AM |
| 2006 Civic Detailed Report | webby | Garage | 2 | 07-06-2005 11:25 PM |
| 2006 Geneva Civic Release | webby | Garage | 0 | 06-23-2005 12:10 AM |
