Install Guide: TWM Short Shift Kit 2006+ Honda Civic / Civic Si - Page 6 - 8th Generation Honda Civic Forum
Old 06-30-2007, 09:06 PM   #101 (permalink)
JMorris's Avatar
James
I just installed my twm kit today and I have a tip for you guys on how NOT to drop the bushings. Well actually I droped them about 20 times but never lost them or had to remove the console. I knew there was no way I could get my fingers in there and not drop the bushings. I didn't like the idea of the fun tack so I came up with my own simple solution. Take some light fishing line tie it through the bushing like a ring on a necklace. put the string under the hole the bushing goes in and pull it up and through with some needle nose untill the bushing is in snug in place, then tie off or tape the loop to the shifter so it holds in place. All you do now is just put the bolts in tighten it part way down. Cut the fishing line and pull it out like dentle floss between your teeth (there is room for the fishing line and the bolt so it slides right out). I could have never even done this with the fun tack. I needed the line to pull them up into place. Hope this helps the guys who don't have any fun tack handy. This may actually be the way to go even if you have it as you will not loose the bushing. Thank you all who contributed to this guide it was very helpful!
JMorris is offline   Reply With Quote
Old 07-01-2007, 04:51 PM   #102 (permalink)
chiguywithsi's Avatar
jay
just installed the ss, base bush, cable bush. wow nice strong feel,great price to from twm
chiguywithsi is offline   Reply With Quote
Old 07-02-2007, 11:30 AM   #103 (permalink)
Can i retain my stock boot/knob? im just not a fan of the aftermarket knobs and stuff. i like the clean look. thanks!
dryerlint88 is offline   Reply With Quote
Old 07-02-2007, 04:16 PM   #104 (permalink)
8thcivic Sponsor
TWM Performance's Avatar
That is a great idea, I'll have to try it next time I install a set.
Thanks,
Kevin
TWM
TWM Performance is online now   Reply With Quote
Old 07-02-2007, 04:19 PM   #105 (permalink)
8thcivic Sponsor
Yes, you can retain the stock shift knob and boot with our short shifter, base bushings and cable bushings. Installing any of the three, or all three items allows you to keep the stock knob and boot.
Thanks,
Kevin
TWM
Old 07-11-2007, 09:02 PM   #106 (permalink)
datbacker59's Avatar
Its a Live2Hustle Thang...
does this fix the notchiness and grind that the Si has?
datbacker59 is offline   Reply With Quote
Old 07-11-2007, 09:06 PM   #107 (permalink)
also should i get the whole short shifter and bushings or what? just bushings?
Old 07-12-2007, 09:48 AM   #108 (permalink)
Tom1222's Avatar
Tom Smith
No, that is a separate issue. There is a Big thread on that right now. It's your sychros. They are toast and need to be replaced.
Tom1222 is offline   Reply With Quote
Old 07-12-2007, 10:57 AM   #109 (permalink)
JasonC.'s Avatar
Thumbs up
Great write up and tips....
Mine goes in the shop on Monday. New Amsoil, Auger Boot, Shifter and bushings and Skunk knob.
Can't wait!!
JasonC. is offline   Reply With Quote
Old 07-12-2007, 10:57 AM   #110 (permalink)
JasonC.'s Avatar
Thumbs up
Mine goes in the shop on Monday. New Amsoil, Auger Boot, Shifter, Bushings & Skunk knob.
Can't wait!!
Old 07-19-2007, 11:20 PM   #111 (permalink)
Jason
I am looking for the blue cap that you can find in picture 11. Does anyone have an extra or know where I can find one besides the dealer...which is charging $80 for the whole kit?
cubzbiggestfan is offline   Reply With Quote
Old 07-20-2007, 11:38 AM   #112 (permalink)
8thcivic Sponsor
I just PM'd you.
Kevin
TWM
Old 07-22-2007, 09:30 PM   #113 (permalink)
lloyd2381's Avatar
just finished installing the TWM short shifter and base bushings...easy, easy...and the result is great.
As others have said...just move the center console back. Once its loose this job is easy...its near impossible to do with the console in place.
lloyd2381 is offline   Reply With Quote
Old 07-31-2007, 09:51 AM   #114 (permalink)
Installed the SS, base and cable bushings this weekend. Love it. This is how the car should have shipped out of the factory. Shift effort is increased a little bit, but I barely feel the 3rd gear notch anymore. Skunk2 shift knob is on the way. Should have it by the weekend. Can't wait...that should hopefully reduce the shift effort.
BERTRON is offline   Reply With Quote
Old 08-01-2007, 07:34 AM   #115 (permalink)
Tom1222's Avatar
Tom Smith
I didn't notice any increase in shift effort!? Quite on the contrary the short shifter made shifts a lot easier with a positive feel. I added the Skunk2 shift knob and I didn't see that much of a difference. The stock knob is actually weighted and does a nice job.
Old 09-06-2007, 12:10 PM   #116 (permalink)
montohill's Avatar
vasi
So the kit would work great without an after market shift knob?
montohill is offline   Reply With Quote
Old 09-06-2007, 12:22 PM   #117 (permalink)
Izzy's Avatar
The short shifter has nothing to do with the shift knob. You'll be fine if you use the stock shifter.
Old 09-06-2007, 03:32 PM   #118 (permalink)
Brian Ko
just got my ss + bushings...didn't really have time to install any of the bushings but installed the ss...real easy (thanks for the great diy), im planning on installing the base this weekend and the cables when my intake comes in...oh yea this was my 1st mod on my si
kosi is offline   Reply With Quote
Old 09-06-2007, 04:02 PM   #119 (permalink)
JMorris's Avatar
James
My first as well.
Old 09-06-2007, 06:27 PM   #120 (permalink)
jay
u guys should try 1 of the twm knobs, i got the type r one and their adjustable so you can bring the knob down so the throw is even shorter
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/16370-install-guide-twm-short-shift-kit-2006-honda-civic-civic-si.html
Parking Brake Adjustment on 2006 Civic with Drum Brakes (Hybrid) - Honda Car Forum - Accord Parts Civic Tuning Acura Racing This thread Refback 02-24-2008 05:18 PM
Civic SI Sedan Comes To America - Chicago Auto Show Debut webby Honda Industry News 11 04-19-2008 10:24 PM
2006 Honda Civic Hybrid Pricing Released webby Civic Hybrid 0 11-30-2005 11:08 AM
2006 honda world news webby Garage 0 07-25-2005 10:31 AM
2006 Civic Detailed Report webby Garage 2 07-06-2005 11:25 PM
2006 Geneva Civic Release webby Garage 0 06-23-2005 12:10 AM
