Has anyone directly wired a radar detector in their 2009 Civic Si? - 8th Generation Honda Civic Forum
Old 06-19-2009, 02:22 AM   #1 (permalink)
Has anyone on here directly wired a radar detector in their 2009 Civic Si? Specifically, using the direct wire smart cord from Escort with any Escort radar detector that can use it.
The only reason I'm asking is I previously bought a Cobra radar detector from BestBuy and ended up frying it by trying to install it using a direct wire kit that was also from BestBuy. Here's what I did: I had the positive wire tapped into the #8 fuse on the fuse box. The radar detector was already switched on and the wire was already plugged into it and I was merely trying to test a ground location. So I started my car, and touched the ground wire to a bolt I was going to use, and I hear a small pop. I look up and see a light smoke coming from the radar detector. I'm pretty sure I went wrong by not completing the circuit (having it grounded before starting the car, plugging the cord into it, and then turning the RD on). But I just want the reassurance of knowing that people have direct wired a radar detector in their 09 Si.
Thanks for any replies.
gregbain2 is offline
Old 06-19-2009, 11:01 AM   #2 (permalink)
chrishann24's Avatar
Chris Hann
i have an o6 and im pretty sure they are all the same. I just spliced into my sunroof power. The grren wire underneath your map lights. super easy to do with only a short amount of wire.
chrishann24 is offline   Reply With Quote
Old 06-19-2009, 11:45 AM   #3 (permalink)
ojefferyo's Avatar
Jeff
i havethe escort 9500 hardwired and no problems, i think the problem you had was something in the wiring itself.
ojefferyo is offline   Reply With Quote
Old 07-07-2009, 07:07 PM   #4 (permalink)
MojoNojo's Avatar
this may not be the type of help you're looking for, but i hardwired my cobra into the moonroof power with a female car adapter, which has a fuse in it, and used the power and ground from that...
MojoNojo is offline   Reply With Quote
Old 11-10-2009, 03:13 PM   #5 (permalink)
pookeye's Avatar
I did Hardwire my valentine one on my civic 2008, and im pretty positive your problem was you didnt ground it before turning your car on... next time ground first, then put positive.. Ground is most important.
pookeye is offline   Reply With Quote
Old 06-21-2010, 08:28 AM   #6 (permalink)
arrest me red si's Avatar
brandon (white boy)
there is a company in norfolk virginia called auto illusions that specializez in built in dash radar detectors they are gps tracked so u get no false reading n the faster u go the farther ur detector detects n also they have laser plates which send an error to the cop to give u time to slow down call nester at 757 472 5507
arrest me red si is offline   Reply With Quote
Old 06-21-2010, 09:30 AM   #7 (permalink)
VTXFrank's Avatar
Tom
I wired mine to the #8 fuse as well. But you need to make sure what "side" you use. The upper or lower. I used my multimeter to figure out where to place the power pin in the #8 slot. I put the pin in the lower part of the fuse block for the #8 and had the ground wire attached to the bolt where most of the other ground wires go before I ever turned the car on. I also have a small, inline fuse on the positive wire, but it came with the hardwire kit I ordered from Beltronics.
VTXFrank is offline   Reply With Quote
Old 07-22-2010, 01:10 PM   #8 (permalink)
Tim Gray
BlendMount.com - Valentine One Radar Detector Mount
that is what I use, took me 30 minutes and it looks stock, ran wire to switched power on #8. Piece of cake.
P.S. Valentine 1 is the best one, everything else is junk... I know this because I tried all the others... I used to cruise daily on I94 from detroit to chicago back in my dumb kid days.. 110mph the whole way if possible.... never got a ticket with the V1... I did with the other junk.
timgray is offline   Reply With Quote
Old 01-27-2011, 05:47 PM   #9 (permalink)
any one have step by step how to hook up the radar to the power in the moon roof thanks for the help
Sooner125 is offline   Reply With Quote
Old 03-06-2011, 12:02 PM   #10 (permalink)
Lex31905's Avatar
Lex Smith
DIY: radar detector hard wire
...? Euless??? TX??? THS??? Maybe yes no? Class 07 here.
Lex31905 is offline   Reply With Quote
nor cal wired on honda meetup and car show off jan 24th 2009 jdm.norcal California North 9 01-26-2009 09:58 PM
Don't the Acura CSX HIDs fit the Civic sedan directly? yacoub Lighting, H.I.D.'s, & Neon 17 12-23-2008 06:11 AM
ROCKY MOUNTAIN RMR-C430-6 Radar Detector with Integrated Radar Scrambler mattSi I.C.E., Electrical, Security, & Navigation 8 02-06-2008 09:22 PM
