2009 Civic 12V Constant Power to Aux Power Outlet - 8th Generation Honda Civic Forum
Old 06-18-2009, 09:20 AM   #1 (permalink)
I just picked up my new 09 Civic EX-L and it has 2 Aux Power Outlets, but both only have power when the key is on, I want the one in the arm rest to have constant power with no key in the ignition, how can this be done?
Andre
Andred1971 is offline
Old 06-20-2009, 01:38 PM   #2 (permalink)
I imagine you would need to pull apart the Power Outlet and hardwire it to your battery or splice into a constant 12V wire. Not sure where there's a constant 12V line, there's probably one leading to radio tho.
If you need a constant 12V power outlet you may want to consider just buying an aftermarket cigarette lighter adapter and wiring it to your battery. It won't be as convenient as the stock outlets, but you should be able to hide it under your the dash or seat so it's not visible. I did this with my old '98 Civic CX hatchback.
Cigarette Lighter Adapter
or 12V Power Socket Plug just cut off the adapter end and hard wire to the battery.
tbone is offline   Reply With Quote
Old 06-23-2009, 09:46 AM   #3 (permalink)
I am hoping someone has done this before and has a pinout for it? Maybe a wire under the armrest, or around the gear shift?
Andred1971 is offline   Reply With Quote
How To: Constant power outlet in trunk Corruptor Do It Yourself Articles 5 06-28-2011 12:53 PM
Question on Power Outlet Vader MD Civic SI 2 01-01-2009 01:01 PM
12v Power FIDO I.C.E., Electrical, Security, & Navigation 28 06-20-2007 11:19 PM
12v outlet = no power 2006silver Mechanical Problems & Technical Chat 7 08-27-2006 06:47 PM
Constant Power Going To My Headunit, Is It A Problem? Chris Dillon I.C.E., Electrical, Security, & Navigation 6 07-07-2006 04:34 PM
