Intake stupidity???? - 8th Generation Honda Civic Forum
Old 05-30-2009, 12:08 AM   #1 (permalink)
Doug
OK, I have a 2007 Si & I do want to increase the intake flow without increasing the exhaust sound....having already done all my former Camaro Z28's mods (when I was still able). I was considering this idea in my tiny little mind...& if this has been proposed before, I apologize in advance (I tried a search)!
My idea is this: Replace the drop in stock filter with a K&N, cut a 4" round hole into the bottom of the stock intake box & rivet a 4" washer Duct intake (such as this: Lambro Industries at Lowe's: 4" x 5' UL Transition Duct Vent Kit), run the lower intake into a position of lower air inflow box & have the lower end secured near the bottom of the vehicle.
I don't see a problem with water-lock (due to the intake being pointed down & the stock intake being operable). Is this a dumb idea or has anybody tried it yet? Any potential problems seen with this idea?
Thanks!
Doug
Kalypso is offline
Old 05-30-2009, 12:11 AM   #2 (permalink)
Zeuceone's Avatar
You can buy a kit from an autoparts store made of plastic just like that.
Old 05-30-2009, 12:15 AM   #3 (permalink)
Taylor Kurtz
its been done. no hydro-lock issues unless you manage to submerge your car in water deep enough to get in through your doors
CanyonDriver is offline   Reply With Quote
Old 05-30-2009, 12:16 AM   #4 (permalink)
F-1 Si's Avatar
Peter
Why not just reuse the intake port on the bottom front of the stock box and re-route to the front of the car instead of the resonator in the fender well?
F-1 Si is offline   Reply With Quote
Old 05-30-2009, 12:32 AM   #5 (permalink)
NitrousG35's Avatar
Never Again!
Doug, I am having a hard time visualizing this. Are you going to keep the stock cold air tubing and then add an additional duct/hose at the very bottom of the base of the airbox? If you do that, I would try and pull air either from the front of the vehicle or the fenderwell area.
On another note, I would give serious consideration to the Amsoil dry type drop in filter that should outflow the K&N which is an oiled type of filter. AMSOIL Ea Synthetic Nanofiber Air Filter (EaA)
I would be glad to help out any way I can. Here is a link to the Mother thread I did on intakes, both aftermarket and DIY. You should be able to get some ideas from that thread. http://www.8thcivic.com/forums/bolt-...iscussion.html
Some cause happiness wherever they go: others whenever they go. -Oscar Wilde
Old 05-30-2009, 03:26 AM   #6 (permalink)
Doug
Thanks Bill!
I just don't have the mobility to get into the routing of the intake anymore. I also have limited resources to build the upper air box to house a cone filter...much less make it look like a show piece! Old Age sucks, avoid it at all costs!
Thanks!
Doug
Kalypso is offline   Reply With Quote
Old 05-30-2009, 10:41 AM   #7 (permalink)
NitrousG35's Avatar
Never Again!
Hey bro, I am 57. I know all about getting older. I wish I could avoid it LOL. Anyway, best wishes on your intake. Let us know how it goes.
Old 05-30-2009, 11:47 AM   #8 (permalink)
TW FA5 FTMFW!!!
sounds like a good idea
09SiDan is offline   Reply With Quote
Old 06-18-2009, 04:10 AM   #9 (permalink)
Doug
Ok...so I did this Instead!
Bill had said he was going to try the K&N Apollo Universal system to me once, so I bit the bullet & gave it a shot!!
Without the tools for rebuilding the MAF housing, etc...I tried the next best thing. I installed a Takeda #1004P, SRI mounted with a K&N Apollo filter using the Honda stock resonator box & cold air intake system. Being an old fart, it took me 6hrs (for a 90-min job) & am planning my interior sound reduction to someone more able than myself!
Anyway, pics & dynos to follow...not being a Folgers kinda guy, this thing screams but I want to hear my tunes. So, the next thing is to dampen the outside noise!
Thanks for your help Bill!
Old 06-18-2009, 04:13 AM   #10 (permalink)
Taylor Kurtz
^ Try dynamatting your firewall.
Old 07-08-2009, 03:12 PM   #11 (permalink)
kingcuongo's Avatar
to the OP: do you have a pix of this setup? ever get that dyno done yet?
kingcuongo is offline   Reply With Quote
Stupidity on clubsi lovecheese Water Cooler 11 11-24-2008 02:50 AM
The stupidity of people:::Owned dcubed121 Water Cooler 3 06-16-2008 06:30 AM
Stupidity is now illegal... cambodianricer Water Cooler 1 04-11-2008 05:04 PM
My first act of stupidity. Sunshine Mechanical Problems & Technical Chat 12 04-18-2007 06:37 AM
The stupidity of some people on ebay RockALittle250 Water Cooler 5 03-14-2007 08:14 PM
