#1 (permalink)
Joseph
DIY: Primary o2 sensor replacement
ok so my replacement came in today
why the need? heres the story: one of my studs on the cat stripped and i changed it, no brainer take a hammer to it, just like replacing wheel studs. replaced it no problem. so i finish installing my apexi WS2 exhaust and i get a CEL. get that checked out, come to find out i broke me first o2 sensor....WTF!! anyways, for those who ever comes across of changing your oem cat studs PULL YOUR O2 SENSORS OUT FIRST!!! i hated the though of this because i was getting my RH that weekend this happened. o2 sensor wasnt so bad, got it off of collegehills honda for about $120 shipped. called autozone they had one "exact thing" for $2XX, i was like yeah right.... ![]() Broken sensor: ![]() This install took me about 15 minutes top. Tools need: 7/8's wrench ![]() Part number for o2 senor ![]() 1st:thing you want to make sure your car is cool 2nd:make sure you have a jack and jack stands. 3rd:after getting under the car locate your PITA...oh i mean sensor. un clip the sensor ![]() ![]() 4th:use a 7/8's to loosen it ![]() 5th:locate the plug where it goes ![]() 6th:unclip the plug ![]() 7th:tighten the new o2 sensor ![]() 8th:connect the plug, clip it back on(i almost forgot) 9th:reset the battery 10th:enjoy having a no CEL ![]() feel free to ask me any questions.
#17 (permalink) |
Location: Seeing the beauty of the world in a drop of morning dew
I am the Juggernaut!!!
The cat for an FG2 is like $1k from Honda
You can get a S2 header for a lot less than that. Last edited by 02civicsi; 09-22-2010 at 09:00 AM. |
#20 (permalink) |
My 07 Si gave me a P0134 code... It's primary 02 sensor... I have a S2 RH and LSD catback... I need to either buy a replacement or clean it right? Or I read u should check ur hoses including my intake right?
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/156520-diy-primary-o2-sensor-replacement.html
| ??? - ??????? - Primary 02 Sensor?? | This thread | Refback | 09-02-2011 03:28 PM | |
| ??? - ??????? - Primary 02 Sensor?? | This thread | Refback | 08-22-2011 09:34 PM | |
| ??? | ??????? - Primary 02 Sensor?? | This thread | Refback | 08-05-2011 05:12 AM | |
| ??? | ??????? - Primary 02 Sensor?? | This thread | Refback | 07-30-2011 01:43 AM | |
| ??? - ??????? - Primary 02 Sensor?? | This thread | Refback | 07-17-2011 11:31 PM | |
| Secondary O2 sensor Replacement | 07 fuji Si | Mechanical Problems & Technical Chat | 10 | 06-07-2009 02:36 AM |
| Primary o2 - CEL | eSeYe | Mechanical Problems & Technical Chat | 8 | 11-26-2007 07:38 PM |
| O2 sensor for 97 Celica replacement | nsl | Garage | 0 | 10-30-2007 06:50 PM |
| Primary o2 sensors | BlackSi10 | Mechanical Problems & Technical Chat | 1 | 03-26-2007 09:37 AM |
