DIY: Simple rear speaker removal (DX/LX/EX/Hybrid) - 8th Generation Honda Civic Forum
Old 05-11-2009, 11:15 AM   #1 (permalink)
GoHuskies's Avatar
I'm me
Got this idea from changing out the map & dome lights. I assume this is probably old news but there is no DIY. If your like me and don't have a resource of DIY websites on hand you might end up doing things the hard way and taking off the entire rear deck. This is easier!
FYI - This is meant to ONLY civics with the pop off cover over rear speakers. No idea if this works for the Sub in the Si.
Tools needed:
- Flat head screwdriver
- 3/8 - 5/16 ratchet head
- wooden/rubber mallet
Step 1:
Remove the rear seat headrests. Just press in the tab on right side when facing them and pull:
Step 2:
Using the flathead screwdriver wedge it into the space between speaker cover and rear deck. Move it around until you find the right spot for leverage.
Step 3:
Work the screwdriver around the speaker cover forcing it up and open.
Step 4:
Speaker cover should pop off like so:
Step 5:
Using Ratchet - remove the one screw holding speaker in place. (Some people mention 3/8 head but the 5/16 fit for me)
Step 6:
Pull on the speaker and yank to the left (center of car) Speaker should slide out. Then just pop off the white tab cable and remove. You are now ready to replace speaker with aftermarket item. Or if your like me leave it empty because you have a sub in the back and want more sound into the car.
Step 7: Pop cover back in place with mallet. Repeat on opposite side as needed.
GoHuskies is offline
Old 05-11-2009, 12:10 PM   #2 (permalink)
Admin Ninja
obert's Avatar
obert
Nice DIY !!!!!
Old 05-11-2009, 12:12 PM   #3 (permalink)
MannyP305's Avatar
Manny PHR3SH™
MannyP305 is offline   Reply With Quote
Old 06-15-2009, 02:27 AM   #4 (permalink)
Dwight
I llike this one. What evere to make life easier
Zmd73 is offline   Reply With Quote
DIY: Rear speaker + sub removal BATANG CITY JAIL Audio 108 02-01-2012 01:58 PM
DIY: Si axleback on DX/LX/EX dentrecords Engine 390 12-27-2011 02:18 PM
Removal of EX/DX/LX spoiler? PSPatrick2 Inside and Out 7 09-30-2008 10:39 PM
rear speaker grille removal on a LX imported_LsedanX I.C.E., Electrical, Security, & Navigation 2 02-13-2006 11:06 PM
