Webby's Minion
![]() Join Date: Mar 2006
Nikon Squad Member #8
DIY, please!
Next NorCal Meet - North Bay http://i79.photobucket.com/albums/j1...ser/GGBsig.gif - 8 t h g e n u s e r - |
Haha. Well, I can't do much for a DIY, but I can tell you what I learned.
First of all, do not pull the pin out from the top of the pedal. I made that mistake and a small spring went flyinging out and cannot for the life of me get it back in there. On the bottom backside of the pedal there is some sort of clip. I'm not exactly sure which way to push it because in my struggle I pretty much destroyed it, but I did have to pull the pedal pretty hard to get it out. Sorry that probably doesnt really help any. I'll try to take a picture in the morning, that will probably give you an idea of how the clip works. |
I ran into this problem also, and as I was twisting it (try to figure out that clip) the top plastic portion broke. So now my pedal isn't connected at the top. But, it broke in such a way as it still rests on top of the input bar.
#10 (permalink) | |
The other two pedals, I tried cutting the pins from the back. Tried popping and prying. The only way I got them off was the grinding head on a dremel. Took 45 mins to get the clutch pedal off before I essentially cut it off. The brake pedal, 1 min grinding the pins from the top. |
#12 (permalink) |
Ok, now I can't get the bottom of the pedal to clip back in. I've been driving around with it loose this whole time (been too busy with school and work to get around to messing with it). Can anyone who has pulled up the carpet or removed the gas pedal from the floor tell me how to get it back in?
#13 (permalink) | |
| Gas Spike Because of Hurricane Rita - $5.00 a Gallon | webby | Water Cooler | 21 | 12-31-2006 02:30 AM |
| Exxon Gas Boycott - urges towns to do the same | webby | Water Cooler | 25 | 08-01-2006 11:22 AM |
| GM incentive: A gas price cap at $1.99/gallon! | CameronJr9 | Garage | 15 | 05-25-2006 08:58 PM |
| gas pedal noise | jd74 | Mechanical Problems & Technical Chat | 3 | 04-22-2006 01:32 AM |
| loose gas pedal? | LsedanX | Mechanical Problems & Technical Chat | 3 | 04-20-2006 10:00 PM |
