Old 04-02-2009, 04:04 PM   #1 (permalink)
dcdttu's Avatar
A/C during Defrost Override - How To
I have used this on previous Civics, and assume it works on most 8th gen ones as well. Perhaps someone can report back...
Do you hate your Civic's A/C turning on automatically when you use defrost? I do. I sometimes just want to keep outside air blowing at the windows and that's enough to keep them from fogging without sapping engine power using the compressor. This worked in the previous 2 generations of Hondas:
Turn Car Off
Turn Temperature Knob To Full Blue (All the way to the left -
Counter-Clock Wise)
Turn Vent Knob To Off (All the way to the left - Counter-Clock Wise)
Hold Down Air Recirculation Button As Well As A/C Button
Keep Both Buttons Depressed and Start Car
Keep Both Buttons Depressed for 7 Seconds
*AC LIGHT SHOULD BLINK*
You will now have control of your A/C regardless of what setting you
are in, to revert back, simply repeat the procedure.
Hope it works! I'll try it on my car once I get it back (a drunk man on a motorcycle hit it....)
dcdttu is offline   Reply With Quote
Old 04-02-2009, 06:33 PM   #2 (permalink)
av911's Avatar
repost
Old 04-02-2009, 06:35 PM   #3 (permalink)
Grey2.0SI's Avatar
Michael
yeah i already did this
Grey2.0SI is offline   Reply With Quote
Old 04-02-2009, 06:49 PM   #4 (permalink)
dcdttu's Avatar
Sorry, I searched for all forms of A/C, Defrost, Defroster, override, cut-off, hack and any other words I could think of... I couldn't find it.
Rough idle (AC / Defrost off) schield Civic SI 9 01-04-2010 05:43 PM
Defrost WITHOUT the AC ON!!! HondaScott BC, Yukon, & NWT 37 04-14-2008 01:54 PM
Remote Start/Alarm w/auto rear defrost? yearight I.C.E., Electrical, Security, & Navigation 17 12-15-2007 12:09 AM
How to disable the A/C while using the defrost mode ? seaman Mechanical Problems & Technical Chat 6 10-22-2007 03:32 PM
Cheat code to override transponder! surf40 I.C.E., Electrical, Security, & Navigation 7 01-01-2007 12:29 PM
