DIY Short Shifter
Mines a little different than those other short shifter DIY where you have to drill your shiftknob. Instead of drilling my shiftknob, I decided to sand down my shifter.
1. removed the shifter Theres a DIY on how to remove the center console and the shifter somewhere on here ![]() ![]() 2. Now you need some sort of a grinder, i used something like this ![]() Now grind it just enough so the shift knob will be able to go all the way down, I stopped at the little things sticking out on the sides of the shifter 3. Now it should look liket his when your done ![]() I painted it black ![]() 4. Make sure the shift knob fits on and stops turning at the point where the numbers on the knob is facing you, or else your gonna have to do a little more grinding. ![]() 5. put everything back ![]() ![]() ![]() ![]() The height where the shift knob sits is adjustable. When the shift knob is all the way down it feels more accurate and precise and the throw is shorter but shifting requires a little more thrust than when the shift knob is sitting up high. When the shift knob is up high, shifting is very light and the throw is longer Last edited by 007FG2; 03-25-2009 at 08:17 PM. |
#4 (permalink) | |
Nice job very good Idea same principal as mine just more risky. |
^^ why in the f_ck do people quote other people that post 10 pictures, makes no sense at all..
Are you so lazy that scrolling to the bottom and clicking the reply button is just not an option? There is a quick reply button ya know ![]() Nice mod btw but I dislike how the leather booth overlaps itself.. Last edited by GreyK20z; 03-30-2009 at 11:12 PM. |
I was thinking about something like this today, but I was more along the lines of can you get away with cutting an inch on the top of the shifter. I want my knob to sit around where the bottom of the stock (ex) knob is now(area with the notch in the knob). I'm pretty sure that If I sand down the bottom like you did I will only need to leave a few threads.
Hopefully this along with a skunk2 or twm knob will get me to where I would like to be. |
#7 (permalink) | |
But I don't understand, how can your throw be shorter if you are not changing the fulcrum point of the shifter. All you are doing is basically lowering the knob. The point of engagement at the gears still remains the same, so the throws aren't shorter, it's a placebo. And it required more force only because you shortened the rod. If the lever arm is shorter, it needs more force to push into place. Just my .02. |
You obviously missed physics class. A rod is on a pivot, the longer the rod, the further you need to move the end, and the less effort needed, to do the same amount of work as if the rod were shorter. Just grab your shifter from the bottom and shift and you will see that you will not have to move your arm nearly as much, but it will be harder.
#9 (permalink) | |
Diy ss Last edited by HTXSI; 03-31-2009 at 01:04 PM. |
#10 (permalink) | ||
Getting ready for winter.
Get it? right? wrong? |
#11 (permalink) |
Yes your angle is the same but it always will be on our civic unless you add a pulley to the cables that has two slots, one with a smaller diameter. Attach the cable going to the shifter on the smaller diameter part and you can reduce the angle.
Your throw on the other hand is how much you need to move your arm which is indeed shortened. ie. \/<--- 1st to second shift.. the distance is greater at the top than if it were half way down( shortened rod) |
#13 (permalink) | |
![]() Just look at the pic for a long time it will come to you ![]() Telling me that my measurements are incorrect. Last edited by HTXSI; 04-01-2009 at 12:31 AM. |
#14 (permalink) |
Look i understand your point but try to see it this way, that picture of the triangle above, the top line say its 10 inches and the bottom one is 5 (just making up numbers) at first you have to **** 10 inches from in 1st gear to 2nd gear, you shortened the shifter and now its only 5 inches from 1st to 2nd, the length of the shift is shorter thus = shorter shifting from 1st to 2nd.
True, the angle will always be the same 10degrees or whatever it is, the angle will never change, the only change is the length of the sides of the triangle (from the bottom vertex) Not so easy to explain, do the opposite make it longer, add some sort of a shifter extender like a feet or two to the shifter to make it longer and shift from 1st to 2nd, you will see its a longer distance to cover from point a to b Last edited by 007FG2; 04-03-2009 at 02:44 AM. |
#17 (permalink) |
I dont understand, I took the nut off and even if I use the stock knob and not grind anything it doesnt hit anything which means it would be pointless to grind away anthing right? The part that you grinded away, if that stayed the same and be stock it doesnt stop the knob from going down the thread does. Can you help me out here lol im so confused
#19 (permalink) | |
It sounds like you are trying to use the stock nob, if so the nob will just not sit as low as the things we are doing. But if you ground down the shift rod like the starter of this thread, and also cut off some threading(just like 1/2 inch) then you could run the nob almost all the way down, like you want to. |
#20 (permalink) | |
Ok I do understand what you guys are saying. Yea I wasn't trying to hate, just didn't understand exactly how your throw was shorter from my point of view. |
| DIY: CT Engineering Short Shifter Installation | BTRobertson | Do It Yourself Articles | 41 | 01-02-2010 11:46 PM |
| DIY: True Short Shifter (almost S2k) | StevoK20 | Do It Yourself Articles | 9 | 10-21-2008 08:22 AM |
| Comptech Short Shifter DIY - WoW So Easy to do!! | Streethonda06 | Do It Yourself Articles | 31 | 06-25-2008 09:59 PM |
| DIY corsport short shifter with a twist | fatality122887 | Bolt-Ons And All-Motor | 16 | 01-18-2008 07:35 PM |
