Diy ss - 8th Generation Honda Civic Forum
Old 03-17-2009, 11:35 PM   #1 (permalink)
HTXSI's Avatar
Jordan
Diy ss
Do it yourself short shifter. Yea, I know sounds dumb.
4 1/2 inch pull center to center
3 1/4 inch pull center to center
How about that. 1 1/4 inches. I actualy had a good idea......That worked.
I will most likely do a full diy on this thing when I have better stuff to work with for now Ill try it on the Dragon. And tell everyone how it works.
Not to mention this + a real short shifter would be an amazingly short throw.
Went to the gap on the 22 and it worked amazing.
HTXSI is offline
Old 03-31-2009, 03:44 PM   #2 (permalink)
collins590's Avatar
you never said what you did.
collins590 is offline   Reply With Quote
Old 03-31-2009, 03:45 PM   #3 (permalink)
Zeuceone's Avatar
this is not a diy but it looks like he got a shift knob that sits lower.
Old 03-31-2009, 03:48 PM   #4 (permalink)
stealth's Avatar
A lower knob and a short shift adapter really make for shorter crisper shifts...
stealth is offline   Reply With Quote
Old 03-31-2009, 03:48 PM   #5 (permalink)
hetroinha's Avatar
what going on ????
hetroinha is offline   Reply With Quote
Old 03-31-2009, 03:50 PM   #6 (permalink)
LakewoodSI2007's Avatar
Francis
can someone explain what just happened?.. lol
LakewoodSI2007 is offline   Reply With Quote
Old 03-31-2009, 03:56 PM   #7 (permalink)
Admin Ninja
obert's Avatar
obert
Old 03-31-2009, 04:14 PM   #8 (permalink)
greenroom1988's Avatar
Matt
great diy!!! rep +1!!!!
sarcasm aside, what did you do??
greenroom1988 is offline   Reply With Quote
Old 03-31-2009, 10:47 PM   #9 (permalink)
collins590's Avatar
Like theres pictures and everything.. seems like you were going to make a diy but just never haha
Old 04-01-2009, 12:15 AM   #10 (permalink)
HTXSI's Avatar
Jordan
Well I was going to do a better one down the road but I will get a REAL diy done as fast as possible.
I took two 3/4 inch thick mdf boards drilled them out with a hole-saw,
glued the two peices togeather, sanded the sides flat with a spindle sander,
drilled the right size hole to fit over the shift shaft,
drilled a hole for the nut from the shaft to fit in,
painted it and put it on. I drove deals gap with it and it worked amazing.
HTXSI is offline   Reply With Quote
Old 04-01-2009, 12:22 AM   #11 (permalink)
stealth's Avatar
So basically it's a home made knob?
Old 04-01-2009, 12:35 AM   #12 (permalink)
HTXSI's Avatar
Jordan
Yes a home made shift knob that reduces shift throw
Old 04-02-2009, 06:11 PM   #13 (permalink)
HTXSI's Avatar
Jordan
Ok here we go.
Worked until 1 in the morning for something that most people wont even like or do.
Things youll need.
I used 3/4 inch Mdf.
http://i363.photobucket.com/albums/o...X/IMAG0398.jpg
A hole-saw. Its all about how wide you want to make the shifter.
http://i363.photobucket.com/albums/o...X/IMAG0395.jpg
Clamps.
http://i363.photobucket.com/albums/o...X/IMAG0396.jpg
A good-ol-drillbity set.
http://i363.photobucket.com/albums/o...X/IMAG0397.jpg
A paddle bit or a bit like this.
http://i363.photobucket.com/albums/o...X/IMAG0402.jpg
A drill and or a drillpress and glue.
Now youll need some other stuff but that will come later.
Take your mdf and drill it out with the holesaw. Two or three holes depending want your shifter to look, I did three.
http://i363.photobucket.com/albums/o...X/IMAG0406.jpg
Sand off any burrs the saw left.
http://i363.photobucket.com/albums/o...X/IMAG0409.jpg
Glue the pieces together.
http://i363.photobucket.com/albums/o...X/IMAG0412.jpg
Clamp them all together.
http://i363.photobucket.com/albums/o...X/IMAG0413.jpg
Let them sit for about 10 to 15 minutes to dry then sand the sides so all of them line up.
http://i363.photobucket.com/albums/o...X/IMAG0427.jpg
Skip the next step unless you are going to shape your shifter.
Get a power drill and a lag or cut-off screw of some sort.
http://i363.photobucket.com/albums/o...X/IMAG0431.jpg
Screw it into a predrilled hole in the mdf(or it will crack it).
http://i363.photobucket.com/albums/o...X/IMAG0428.jpg
http://i363.photobucket.com/albums/o...X/IMAG0429.jpg
Use a piece of sand paper or a sanding block to sand the shifter down to any shape you want, by drilling back and forth on the sand paper.
http://i363.photobucket.com/albums/o...X/IMAG0430.jpg
Drill using a 5/8 paddle bit in the top of the shifter deep enough for the nut to fit in.
http://i363.photobucket.com/albums/o...X/IMAG0436.jpg
Drill using a 11/16 paddle bit for the head of the nut to fit in.(Dont have a pic but just deep enough to look like this)
http://i363.photobucket.com/albums/o...X/IMAG0437.jpg
Drill out the bottom up to about a half inch from the nut hole you just drilled using the big bit in the begining of the thread.
http://i363.photobucket.com/albums/o...X/IMAG0432.jpg
http://i363.photobucket.com/albums/o...X/IMAG0433.jpg
I added this because I thought it looked better.
http://i363.photobucket.com/albums/o...X/IMAG0438.jpg
And add washers to add weight and make it sit at the right height.
http://i363.photobucket.com/albums/o...X/IMAG0440.jpg
This is what it should look like.
http://i363.photobucket.com/albums/o...X/IMAG0441.jpg
Shorter than stock and a shorter throw.
http://i363.photobucket.com/albums/o...X/IMAG0444.jpg
Stock height.
http://i363.photobucket.com/albums/o...X/IMAG0445.jpg
After.
Paint it whatever color you want and your done.
Black
http://i363.photobucket.com/albums/o...X/IMAG0446.jpg
3rd
http://i363.photobucket.com/albums/o...X/IMAG0451.jpg
4th
http://i363.photobucket.com/albums/o...X/IMAG0452.jpg
K done.
Old 04-04-2009, 12:11 AM   #14 (permalink)
I feel sick
drush is offline   Reply With Quote
Old 04-11-2009, 04:06 AM   #15 (permalink)
portabuddy's Avatar
Thats Mr.Bart to you!
lol dude you made a wooden snift knobe, or a woden knob... Dude, your car has a woody.
I like the DIY laythe but in general it looks like crap and is a fail. but thats just my opinion.
Life dosn't have a reset button, if it did you may as well turn the game off. -portabuddy
Originally Posted by George Carlin
"Its called the American dream, because you have to be asleep in order to believe in it."
portabuddy is offline   Reply With Quote
Old 04-13-2009, 12:21 PM   #16 (permalink)
HTXSI's Avatar
Jordan
Well thats great take your opinion and shove somewere the sun dont shine.
Cause it works, and it looks fine, and its not made out of wood its mdf.
DIY: Installing SS Brake Lines twistedframe Suspension 60 02-05-2012 03:10 AM
DIY: Comptech SS Install NBP~FG2 Engine 77 03-24-2011 05:15 PM
Cobalt SS/TC & Civic Si (this isnt another SS vs Si Thread) Crucifer Dealership Experience 194 08-22-2008 05:45 PM
TWM SS vs. Comptech SS vs. All other SS Si Speed 317 Bolt-Ons And All-Motor 63 11-28-2007 08:03 PM
SS Brake line DIY? polgas07 Do It Yourself Articles 1 05-15-2007 02:43 PM
