DIY: Another Rim Painting DIY - 8th Generation Honda Civic Forum
Old 02-02-2009, 10:23 PM   #1 (permalink)
007FG2
You'll need some materials:
1 Can of spray paint, your choice of color, I choose gunmetal (car spray paint)
1 Can of clear coat, I used krylon
1 Can of Red spray paint Krylon for Plastic (OPTIONAL)
1 Can of primer (OPTIONAL)
Some 3M scotch-brite or fine steel wool
3M blue tape, i think its 1/4 inch (OPTIONAL)
Masking tape
News paper
some 3x5 index cards
heat gun (OPTIONAL)
windex (OPTIONAL)
rubing alcohol (OPTIONAL)
And watever rim your painting
Originally Posted by joey.walla View Post
How long did this take you? Awesome write up too. I'm at work so I can't see the pics but when I get home I'll go to town on this thread. hahaha
Took me about a 5 days, 1 day to finish each wheel. I did this in my basement while it was snowing out. I had to paint one rim at a time, I put the spare tire on to drive around while doing this project. I didn't bake it, I let it air dry overnight in freezing weather.
STEP 1
Remove the centercap and sand it down with the scotch-brite, you want to sand all the shiny spots so that the paint will stick. Make sure you sand it down very well and dont forget the inside of the rim (the wheel wall or whatever its called)
STEP 2
Use windex to wipe it down and remove all the dust, or just simply wash it very well. Once its dried, get some news paper and tape and cover up the tire
STEP 3
Insert index cards. Dont forget to tape off your valve stem unless you want to paint it. Now before you prime, Wipe it down with rubbing alcohol, that will remove all the oil and grease from your hands. Dont touch the rim after you wiped it down with alcohol, now give it a light coat of primer (a light coat so that the following coats will have something to stick to, too much and it will drip and run everywhere)
STEP 4
Apply several coats with drying time between each coat. I also painted the inside of the wheel so it would match. After several coats or until you cant see the metal/old paint, it should look like this
STEP 5
Once the primer is dry, I used the heat gun to make sure it is very dry, I sprayed the outer part of the rim red, I gave it 2-3 coats
STEP 6
I used the heat gun to make sure it is super dry, i Used the 1/4 tape and masked off the outer edge
STEP 7
Now use masking tape and tape off the gap from the rubber to the blue tape, It should look like this
STEP 8
Now Hit it with the color, Remember a very light first coat. I gave it about 3-4 coats
STEP 9
Remove the masking tape and remove the blue tape slowly. Put the index cards back in and hit it with a few coats of clear. Final product should look like this
CENTER HUB CAPS
1. Sand down the center hub caps
2. Prime it
3. Paint it
MAKING THE SIGN
I got the vinyl paper from a 'fast sign' shop, I showed them what I was making and they told me it would cost like $15, I asked to buy just the paper and they gave me a feet of they vinyl for free. Takes about 1 hour from start to finish
1. I took the center caps out and scanned it
2. I cut out the sign and a piece of of vinyl
3. I put the sign on top of the vinyl and cut it out
4. Now I put the sign in the middle of the center hub cap after its painted and dried (yes I forgot to mention that I sanded and primered it, YES I also sanded the H but I didnt sand it out completely, just enough to to make sure its flush so I can primer and paint it. I primered because I wanted to make sure the paint wasn't going to bleed through)
5. Couple of clear coats after the sign is put on so the sign wont fly off when I drive
Originally Posted by Br3aker4lyfe View Post
Cant wait till i get my si wheels for my lx. Im gonna paint it black with a blue lip ^_^
whered you get the center caps O.o not the vinyl just the center caps its self
EDIT:
Read the first step.... did you sand out the original H's? O.o
Originally Posted by TcivicT3 View Post
what brand of gunmetal is that?
007FG2 is offline
Old 02-03-2009, 02:58 AM   #2 (permalink)
my real name is not Gary
any chance paint will peel off?
garyxchan is offline   Reply With Quote
Old 02-03-2009, 03:09 PM   #3 (permalink)
That's wicked, i was looking to doing something like this very soon...
08S| is offline   Reply With Quote
Old 02-03-2009, 03:35 PM   #4 (permalink)
DUB2CRS's Avatar
Chris
Not a huge fan of painted stockies with the exception of a few members' FA5s, but it looks like you did a really good job.
If I ever wanted to paint my wheels, I'd use this DIY as a guide
DUB2CRS is offline   Reply With Quote
Old 02-03-2009, 03:50 PM   #5 (permalink)
civicsi13's Avatar
Marshall
REALLY good DIY!!! this one will definitely help if if i ever paint my rims.
civicsi13 is offline   Reply With Quote
Old 02-03-2009, 04:07 PM   #6 (permalink)
civicsi626's Avatar
Jaime
nice write up
civicsi626 is offline   Reply With Quote
Old 02-04-2009, 05:58 PM   #7 (permalink)
007FG2
I've had them on for a couple weeks nows, no chips yet
007FG2 is offline   Reply With Quote
Old 02-04-2009, 10:01 PM   #8 (permalink)
jrfiji20si's Avatar
jordan
good dyi i'm going the powder coat route but fyi you don't need to use primer unless you go down to bare metal this will save you a few bucks
jrfiji20si is offline   Reply With Quote
Old 02-04-2009, 10:30 PM   #9 (permalink)
nycclaye's Avatar
Nick
great job!!!
nycclaye is offline   Reply With Quote
Old 02-04-2009, 10:31 PM   #10 (permalink)
Admin Ninja
obert's Avatar
obert
Great job,I really like the way they turned out.
Old 02-08-2009, 02:37 AM   #11 (permalink)
Esli Jair Perez
tu7hbg
Perez_FA5 is offline   Reply With Quote
Old 02-08-2009, 03:13 AM   #12 (permalink)
TcivicT3's Avatar
TcivicT3 is offline   Reply With Quote
Old 02-08-2009, 02:43 PM   #13 (permalink)
Br3aker4lyfe's Avatar
Philjay
EDIT:
Br3aker4lyfe is offline   Reply With Quote
Old 02-08-2009, 02:47 PM   #14 (permalink)
joey.walla's Avatar
Joey
joey.walla is offline   Reply With Quote
Old 02-08-2009, 03:18 PM   #15 (permalink)
Demisedgabe's Avatar
Gabriel
rims look good.
not feeling the pin stripe.
Demisedgabe is offline   Reply With Quote
Old 02-08-2009, 03:30 PM   #16 (permalink)
07ASMSi's Avatar
David
nice diy info, like how it turn out. Anyone here have a ASM coupe with gunmetal or black civic si rims powder coated? Got me thinking of painting my stock si rims..
07ASMSi is offline   Reply With Quote
Old 02-08-2009, 03:35 PM   #17 (permalink)
24boosted's Avatar
Good job on the wheels, body work need some attention though.
24boosted is offline   Reply With Quote
Old 02-14-2009, 11:33 PM   #18 (permalink)
stranger21's Avatar
I painted mine last summer. Gone thru winter with all the salt. No chips ANYWHERE!!!
stranger21 is offline   Reply With Quote
Old 02-15-2009, 07:09 PM   #19 (permalink)
FG2BoostCoupe's Avatar
Location: Point Pleasant,NJ is my home. Orlando,FL for now
Smitt
look nice back yard time attack style
FG2BoostCoupe is offline   Reply With Quote
Old 02-15-2009, 07:11 PM   #20 (permalink)
07mugencivic's Avatar
ToE kNeE
nice....
DIY: Painting your R18 Engine cover and more (Pictures) sk8nava Engine 332 02-07-2012 05:00 PM
my little diy on painting a si grille ameuba10 Inside and Out 44 07-22-2010 02:54 PM
DIY: painting wheel trim jackolee Do It Yourself Articles 7 10-12-2007 01:54 PM
A good tutorial for DIY for painting rims. Bubble Gum Jr. Wheel And Tire Upgrades 1 05-22-2007 12:48 AM
My Car and my DIY Rim painting NeighbourFromTheNorth Introduction & Pictures 5 09-26-2005 04:05 PM
