DIY: Lower Tie Bar Braces (Rear) - 8th Generation Honda Civic Forum
Old 01-04-2009, 03:52 PM   #1 (permalink)
Jason
This is a PARTIAL DIY on the GTSPEC Rear Lower Tie Bar Brace on a 2008 Si Sedan.
1.) Jack up the car utilizing the pinch-welds just forward of the rear tires. Do NOT jack off the tie bar braces as you will hate yourself forever. Also make sure to put some kind of block infront of the front tires AND put it in first. This should help eliminate the car wanting to roll forward.
2.) Remove the rear diffuser, this will include 3 of the Honda factory clips and 3 10mm bolts. WARNING:: I found a TON of little pebbles/road dirt had found their way up there, wear safety glasses
Here is the diffuser removed.
3.) Find the center points for the rear lower tie bar braces, they are pretty obivious but here is the image for reference.
4.) Using an impact (it sucks without one!!) loosen up the bolt until you have it completely unthreaded.
5.) After this point be ready for all hell to break loose, but here is how we figured to make it more managable. Using a block of wood as long as the lower tie bar, use a floor jack and put pressure on the lower tie bar, if you're too high or too low, the bolt will not easily pull out. After this pull out the bolt, put the brace on and push the bolt back in. Using a BFH give the bolt a couple good hits (otherwise it will not properly seat and the threads won't grab)
Don't torque the bolt down just yet, but make sure its pretty well threaded in.
Lower the jack and repeat on the other side. Sorry for the lack of pictures, we actually learned the hard way about putting the jack under the lower tie bar and it fell out, DON'T LET THIS HAPPEN!!
The rear diffuser will NOT fit back on with the tiny factory bolts, you will need something significantly longer for it to thread properly, but it will go back WITHOUT being cut or modified.
Make sure to get your alignment checked, especially if the brace moved at all.
Xaositek is offline
Old 01-04-2009, 04:00 PM   #2 (permalink)
buurner's Avatar
Bottles
Great Write-up I have a friend that let the back half down lol it took him forever to get it back in lol
buurner is offline   Reply With Quote
Old 01-04-2009, 04:03 PM   #3 (permalink)
a1j7g's Avatar
Andy
Sweet good job! +1
a1j7g is offline   Reply With Quote
Old 01-04-2009, 04:20 PM   #4 (permalink)
joey.walla's Avatar
Joey
QUestions
1) Notice any difference with this?
2) Did you put something in front of the front tires so the car didn't roll? I have to install a rear sway bar but don't want to jack up the front and back.
Thanks
joey.walla is offline   Reply With Quote
Old 01-04-2009, 05:21 PM   #5 (permalink)
Jason
Notice any difference? Yes I did - when I go into a corner with any amount of speed I can easily handle it without issues. Even with the factory suspension I noticed it helped. You will not notice it at all in a straight line, but when cornering the body rolls seems much less.
2.) Yeah I had a cinder block infront of the front tire - I'll toss that into the DIY now.
Xaositek is offline   Reply With Quote
Old 01-04-2009, 10:56 PM   #6 (permalink)
joey.walla's Avatar
Joey
thanks bud.
Old 01-04-2009, 11:23 PM   #7 (permalink)
Admin Ninja
obert's Avatar
obert
Nice,thanks for sharing.
Old 01-04-2009, 11:38 PM   #8 (permalink)
07LXcoupe's Avatar
Tony
I have a general question for every one with the rear lower tie bar.
Who has actualy put the under panel back on and who has left it off?
Has the people that left it off seen a change in gas mileage or do you guys think it wont make that much of a difference?
07LXcoupe is offline   Reply With Quote
Old 01-05-2009, 08:01 PM   #9 (permalink)
Jason
I left it on - used some new bolts and it fits without much effort. Its actually protecting the spare tire wheel from alot of road crap. It also keeps air from getting trapped inside the bumper cover and putting unneeded wear on the supports. The thing weights less then 2lbs and it takes two 15 cent screws to reattach.
Just my two pennies I'd always say put it back on, it was there for a reason.
Old 02-18-2009, 01:30 AM   #10 (permalink)
what is the new length of the screws to put the rear diffuser back on ? thank you
vspecll is offline   Reply With Quote
Old 12-30-2009, 05:40 PM   #11 (permalink)
B MAN's Avatar
Brian
doing this soon
i just got an alignment today tho
u think i can really throw much off?
B MAN is offline   Reply With Quote
Old 12-30-2009, 10:46 PM   #12 (permalink)
IceMurder's Avatar
Chris
it won't throw off your alignment
IceMurder is offline   Reply With Quote
Old 12-30-2009, 10:48 PM   #13 (permalink)
IceMurder's Avatar
Chris
i left my diffuser off. the bar looks sick from behind the car and i noticed absolutely no change in gas mileage, i've also had the bar on for over a year
Old 12-30-2009, 10:52 PM   #14 (permalink)
B MAN's Avatar
Brian
u can still see it even with the rear diffuser? pics?
Old 12-30-2009, 11:14 PM   #15 (permalink)
IceMurder's Avatar
Chris
no, i left my diffuser off. you can't see it if you reinstall your diffuser.
Old 12-31-2009, 02:52 AM   #16 (permalink)
B MAN's Avatar
Brian
is that safe?
Old 12-31-2009, 03:01 AM   #17 (permalink)
Huckleberry's Avatar
Jesse
yes.
it's a y diffuser anyway.
http://farm3.static.flickr.com/2025/2714869979_81026334fa_o.jpg
August 6, 1969 – October 21, 2003
Huckleberry is offline   Reply With Quote
Old 12-31-2009, 04:29 PM   #18 (permalink)
IceMurder's Avatar
Chris
Originally Posted by B MAN View Post
is that safe?
why would it be unsafe...it's a piece of plastic...
Old 12-31-2009, 06:46 PM   #19 (permalink)
B MAN's Avatar
Brian
Originally Posted by Huckleberry View Post
yes.
my wheel liner is just a piece of plastic, i take that off and next time it rains im in trouble
isnt that gas tank around there? i know it cant cover it, but whats there that might need protection from rain? is the metal underthere rust proof/resistant atleast?
Old 12-31-2009, 07:03 PM   #20 (permalink)
IceMurder's Avatar
Chris
actually if you took the wheel liner off it wouldn't make a difference, your engine would just get dirty. I've had my rear tie for a year now with no diffuser and everything under the car still looks fine if that helps any.
DIY: 06+ FG2 P2R Rear Lower Tie Bar Evasive Suspension 108 12-28-2011 10:45 AM
What is the difference & benefits between a rear sway bar and a lower rear tie bar? irichard Suspension and Brakes 12 08-13-2009 10:58 AM
rear lower tie bar question Detox Suspension and Brakes 36 03-12-2009 11:33 PM
Corsport front lower tie bar,H brace, rear lower tie bar. Are they good? Razor4ever Suspension and Brakes 21 11-26-2008 04:36 PM
Megan Racing: Fron Lower Tie Bar, Front lower H-Brace, Rear Lower Tie REVIEW Streethonda06 Suspension and Brakes 23 01-08-2007 02:27 AM
