hi beam relay
Hello,
I'm working on my daughter's 2006 Civic. her lights are stuck on hi bean. Does anyone know where the hi beam relay is? I assume it is stuck in the closed position. When I pull your fuse for it the lights go to low beam. Thank You, Devon |
There's no high-beam relay. The high-beam circuit is controlled by high-beam transistors and a low-beam relay, all located in the MICU.
I take it you are pulling fuse #18 which is a 20 amp fuse located under the dash? Last edited by The Power of Dreams; 12-13-2008 at 06:27 PM. |
Okay, well, I think the easiest thing to do is test the combination light switch.
A lot of the other diagnostic troubleshooting requires an HDS (Honda scan tool, if you will) and special connectors that plug into the MICU/ relay box. Anyway, let me know if you're interested in testing the combination light switch and we'll go from there. It will involve removing the steering column covers (top and bottom) located on the steering wheel and the dashboard lower cover. Then, removing the combination light switch from the steering column. All pretty easy. Where are you located? Last edited by The Power of Dreams; 12-13-2008 at 06:39 PM. |
| Relay and grounding | joenguyen | Lighting, H.I.D.'s, & Neon | 8 | 05-31-2007 08:53 PM |
| Does not know how to work the relay harness | thaijai114 | Lighting, H.I.D.'s, & Neon | 2 | 05-23-2007 09:17 AM |
| Any one use the Relay? | thaijai114 | Lighting, H.I.D.'s, & Neon | 6 | 05-05-2007 03:13 AM |
| quick question: high beam or low beam | falkon57 | Lighting, H.I.D.'s, & Neon | 0 | 02-24-2007 01:42 PM |
| Relay???? | 1CLNSEDAN | Lighting, H.I.D.'s, & Neon | 3 | 06-16-2006 04:09 AM |
